Tunnel ram tuning a c3 for 5000ft
Old 03-01-2017, 03:12 PM
Karl Butler
2nd Gear
Karl Butler's Avatar
Default Tunnel ram tuning a c3 for 5000ft
I just bought my first c3 at sea level but I live at 5000+ feet I have a big block 454 and two holley 600 double pumpers on a tunnel ram. Do I just need to mess with the just bring them 3 sizes down and mess with the idle mix screws or is there more?
Old 03-02-2017, 07:11 AM
gkull
gkull's Avatar
Received 1,338 Likes on 1,063 Posts
I live at 5000 also and I had a tunnel rammed street rod. Yes 2 3 jet sizes and bump up the timing the same amount and readjust the idle mixture to get the best vacuum
Old 03-02-2017, 01:06 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
If you want to go a step further and can spare 200 bux call Summit and get thier AEM 02 sensor kit you can really tell more via gauge unles you got a good feel for things.
Old 03-04-2017, 11:01 AM
cagotzmann
cagotzmann's Avatar
I live @ 2300ft. The stock holley 770 avenger cam with 72-75 jets. Primary / Secondary. and a 6.5 power valve. 1/4 mile times 14.4 sec. 104 MPH
I have a zeitronix o2 data logger for each bank of cylinders. 2-4-6-8 and 1-3-5-7.
http://www.zeitronix.com/
This recorded afr in the 10 range for WOT.
I ended up at 69-74 with a 8.5 power valve.
AFR now in the 12.5 - 13.3 range with a 13.18 1/4 mile times @ 108.2 MPH
I see you have 2 options.
1. get a AFR tool / kit to get it dialed in correctly
2. go to the track to maximize MPH at the end of 1/4 mile. trail and error method.
but at 5000ft you will need to decrease jets sizes and play with timing.
I also have a programmable MSD unit to make any timing curve, which was very helpful at the track. It takes 2 minutes to make adjustments and take another run.
Here is a example from the data logger.
I am logging AFR / RPM / Vacuum / Sensor voltages etc.
To Tunnel ram tuning a c3 for 5000ft
Quick Reply: Tunnel ram tuning a c3 for 5000ft
