Wipers not working
Wipers not working
With the possible bad weather this weekend (naturally) I decided to get new wiper blades for the '69. Problem is the wiper motor won't run. The last time I checked it was about 2 months ago and all was well.
What I have is....12v to the switch. The door opens and I can hear the relay pick for the motor but no movement.
Will the wipers run without the engine running?
Hi , Is the switch ( the one that you use to park the blades on the windshield to replace the blades ) below the steering column turned to on , and are the wiper blades maybe locked together ? Pretty common occurance, it has hapened to me more then once. Peace,,,,,,,,,,,,,Craig
