Need Frame Welded
Need Frame Welded
MY frame has a few spots rusted the whole way through. The worst spot is under the drivers side door towards the front it has about a 1" X 3" hole completly rusted through.Also a few spots on the back where the frame starts to go up towards the back wheel. Can these frames be safley welded without removing the body ? Have any of you reading this had a lot of frame damage repaired without a body off restoration? Do any of you know of a shop that could do this , For a reasonable price , around Lancaster PA. ?
I had the Guys at Mic's Auto do some welding on my Caddy. The Corvette may be a different animal with the fiberglass body. tale a look at micsauto.com they are on the Pa NJ boarder.
Others that have been there done that should chime in but if it looks bad with the body on it will probably be worse when you get the body off
This looked salvagable until I pulled the body off
Steve
Steve
The frames on these cars are very prone to rust in the area you have described. It maybe a good idea to explore the rocker chanel and the rearward doorjam metal(were the door stricker is located) for rust aswell. You may have to cut some fiberglass to further investigate this. You can remove the access panel in the rear wheel well for the body mount for a quick check. You will need a good flash light and a scrapper. To check the rocker channel..remove the lower trim peice the goes under the door. Reach up underneith between the frame of the car and the fiberglass. You will feel some metal under there. If you can move this metal with just finger pressure or if it starts flakeing away then you have some rust issues that will need to be taken care of.
HTH
Tom.
HTH
Tom.
I bought the car like that knowing the frame was bad turned out to be worse than we all thought.
Steve
Steve
My frame was similarly hammered. Couldn't really see it fully until the body came off. This can be very dangerous to drive. Also, fiberglass is flammable! Welding in close proximity to the body could cause a fire.
If you are serious about your car - pull the body off. Repairing the frame is no small job. In fact, I replaced my entire frame (found an 82 frame for $200.00 or so) Had to fab up the rear part but it came out straight as a rail and the body fit the first time!
If you don't think the car is worth it - get rid of it and start with another. Just my 2 cents...
Originally Posted by rustbucket80
How could that frame you pictured stay together?
That was the worst side and it didn't take much to cut throught it but believe it or not it held my weight when I stood on it
Steve
Steve
Steve
