Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-03-2004, 10:35 AM   #1
websparks
Junior Member
Default Bolt-On Horsepower?
Looking for ideas on "bolt-on horsepower" to get my 76's stock L-48 at 190 horse up to something in the range of 300+. I'm planning on pulling the engine out in a month or so and want to start getting lined out to minimize "stand-time".
Not looking for anything too radical (like cutting holes in the hood ... ), but this 190 is just too anemic. All ideas are appreciated.
Mike
websparks is offline   Reply With Quote
Old 09-03-2004, 10:43 AM   #2
SteveG75
CF Senior Member
SteveG75's Avatar
Heads - Something nice like AFR's. 64cc chamber will get you up to abot 9.5:1 compression
Cam - 210-220@.050 lift range works good for a 2000-5500 rpm power range (Comp XE262, Comp HE268, Crane Powermax 272 are all popular)
Good intake - Performer RPM is popular, Weiand 8004 is also good.
Ignition - Adjust timing per Lar's tech paper
Carb - Rejet/tune Q-jet or go for a Demon
Exhaust - Headers to true duals. Dynomax Cerama-coats are a good deal.
I did all this the first time round and the car pulled hard and still got 18-19 mpg.
__________________
Steve G.
1975 496 Tripower/T-56 Magnum/ Ramadie-built 3.73 12 bolt/FE-7 convertible.
1977 Ferrari 308 GTB. Bone stock.
2003 Chevrolet Avalanche. Daily driver and tow vehicle.
SteveG75 is offline   Reply With Quote
Old 09-03-2004, 11:17 AM   #3
Beasley's 76
CF Member
Support Corvetteforum!
Beasley's 76's Avatar
When I went through this two years ago after comparing costs and seeing what could be done. I decided to replace the L-82 in my 76 with a GM Crate Motor 350HO 330HP. I was able to order the Vortec Long block that came with a nice set of Chrome Valve Covers, I added the Edlebrock intake and a Holley 650. I could have reused the Old Carb but chose to go with everything new. The Engine, Distributor gear and Flywheel costs me $2289 including shipping from Bobby Murray Chevrolet. My corvette is now my most dependable vehicle in the driveway now, that includes a Honda Accord. For the two years since I put the engine in I have had no problems and it has performed beyond my expectations. I installed new Headers and Flowmasters and it sounds great, the cam lopes good and has great response.
My only complaint with my car is no A/C and without an overdrive it sucks taking road trips, I run about 3500RPM at 70-75 mph.
I'm about to install a T-56 6 speed within the next two months and I can't wait to get it installed have two extra gears for Interstate driving!
You can view my motor under the pics on the new upload page once it gets back up and running.
Hope all goes well!
Beasley's 76 is offline   Reply With Quote
Old 09-03-2004, 11:25 AM   #4
stingr69
CF Senior Member
stingr69's Avatar
Cat, heads, cam, ignition. These are the mods I would make first.
These are the basic mods that later C-3's need.
The factory cat is VERY restrictive so that needs to be addressed first. The heads are the biggest limiter of power after that on any engine. These 2 changes allow you to make other mods that will work. The L-48 cam is designed to work in station wagons and 4 door sedans so that needs to be addressed. Even the '69 350/350 cam would be an improvement and was designed to work with the Vette vacuum accessories. That cam is worth considering. The ignition is pretty good as is but the curve setup is for emissions so that is a low budget easy mod.
The cost/benefit ratio gets higher after that.
-Mark.
stingr69 is offline   Reply With Quote
Old 09-03-2004, 11:41 AM   #5
jcswm
CF Senior Member
jcswm's Avatar
Holley makes Systemax kits.... cam & Intake or cam, heads & intake
one of those kits with some headers looks like a pretty simple & cost effective way to bolt on some serious HP.... The one kit claims 425hp last time I looked!!!
Good luck & have fun building up your toy!!!
John
Link to kit info
jcswm is offline   Reply With Quote
Old 09-03-2004, 11:52 AM   #6
marshrat99
CF Senior Member
marshrat99's Avatar
[QUOTE=SteveG75]Heads - Something nice like AFR's. 64cc chamber will get you up to abot 9.5:1 compression
QUOTE]
I'm supposedly sitting at about 350hp using Dart 180 Iron Eagle heads with 64cc chamber, flat top pistons, Comp XE262, Performer EPS intake, 9.7:1CR, stock HEI ignition per Lar's, Holley Street Avenger carb
marshrat99 is offline   Reply With Quote
Old 09-03-2004, 11:52 AM   #7
Corey_68
CF Senior Member
Corey_68's Avatar
First I go with a nice set of headers, it is a mod that you WILL feel a difference with. Second I go with a cam and intake and maybe a head swap.
Corey_68 is offline   Reply With Quote
Old 09-03-2004, 11:56 AM   #8
Fevre
CF Senior Member
Fevre's Avatar
Quote:
Unless you upgrade your exh system you will be chocking all your other mods, prolly get about 20-30 hp and torq from headers and true duals. Then when you move on to other mods you will get the full benefit from them.
Fevre is offline   Reply With Quote
Old 09-03-2004, 05:39 PM   #9
EDDIEJ82
CF Senior Member
EDDIEJ82's Avatar
Nitrous......
EDDIEJ82 is offline   Reply With Quote
Old 09-03-2004, 05:47 PM   #10
pillowmeto
CF Senior Member
pillowmeto's Avatar
Send a message via AIM to pillowmeto
John
Link to kit info
There was a guy at carlise that bolted on the same kit, made 250 rwhp on a 79 L48, so thats about 300 flywheel
MAtt
pillowmeto is offline   Reply With Quote
Old 09-03-2004, 06:08 PM   #11
mandm1200
CF Senior Member
mandm1200's Avatar
Quote:
I can't argue with your logic, as that is the first thing I done (upgrade to headers and true dual exhaust). The exhaust will have to be modified to something less restrictive.
Someone else mentioned the 350/350 cam. I haven't seen someone mentions that cam before. I had a mid 70's Camaro that I installed that cam into, along with some other mods like intake and headers. It made a world of difference. Good performance and sounded good.
mandm1200 is offline   Reply With Quote
Old 09-03-2004, 06:15 PM   #12
pillowmeto
CF Senior Member
pillowmeto's Avatar
my plan
882 casting heads, 2.02 and 1.6 valves, mild porting by me
edlebrock torker intake
edlebrock performer carb
shorty headers, 2.5"duals, H pipe
stock HEI recurved
cam, I have a 327 350 cam and lifters but i migth get a newer better profile.
expected hp, a bit over 300 at the flywheel
so its not the best set up combo, but if i were to tell you what i paid for each item i dont think youd argue with me on it
MAtt
Old 09-03-2004, 08:20 PM   #13
glen242
CF Senior Member
Quote:
Originally Posted by pillowmeto
my plan
stock HEI recurved
MAtt
882 heads are prone to cracking. A dual plane intake MIGHT be better suited. Why shorty headers?
__________________
'76 L-48, 4-Speed, 3.36
383 with Eagle 3.75 crank & 5.7 SIR rods
Speed-Pro Hyper 12cc dish pistons
Centerforce II clutch
'0' deck block
Internally balanced
Comp Cams XE274 cam & Roller Tip Rockers w/Crane Posi-Locks
Accel distributor
Trick Flow 23 degree heads
Edelbrock Performer RPM Intake
Correct Stock Q-Jet with professional rebuild
Dynomax Jet Coated Headers & Chambered Exhaust
Big Block Radiator Core w/Permacool Fan
Hurst Competition/Plus shifter
glen242 is offline   Reply With Quote
Old 09-05-2004, 11:55 PM   #14
websparks
Junior Member
So what's the best way to get around the cats?
Old 09-06-2004, 08:36 AM   #15
Ganey
CF Senior Member
Ganey's Avatar
Exhaust-
http://www.corvettefaq.com/c3/ganeyexhaust.htm
Cam & intake at same time.
Heads.
__________________
GANEY
CORVETTE 77 385CI 6.3L Hi-Perf. FE-7 Sus.
GANEY Corvette Forum Site BB/SB Comp Cams Edelbrock RPM Holley DP Dynomax
www.kcm.org
Ganey is offline   Reply With Quote
Old 09-06-2004, 10:45 AM   #16
76REDSTINGER
CF Senior Member
76REDSTINGER's Avatar
i just switched from a TM-1 single plane to an EPS performer dual plane
BIG difference on throttle response, low end better
also on sizing a carb i read that if you are drawing less than 1.5 in/mg
at WOT the carb is too big.........any one else seen this?
any opinions on World S/R heads ? just chased down the casting NO's on mine.
also noticed the no performance crate motors under 400 HP have a carb bigger than 650 cfm........bigger isnt better, if you cant use all the fuel.
R.
76REDSTINGER is offline   Reply With Quote
Old 09-06-2004, 11:02 AM   #17
Uriel
Junior Member
Those Holley Systemax kits look pretty cool. I have a '77 that's basically stock (L-48 with the smog stuff removed, dual exhaust) and I've been thinking about some upgrades. I think my valve guides are on their way out (some blue smoke on start up) and I figured it would make sense to rebuild, get new cam/heads/intake/headers at the same time. Now as a newbie, it really is overwhelming the amount of choice in parts that are available and to me this kit seems like a godsend. Trouble is I don't really want to spend too much money. It'd be the top Systemax kit I'd be looking at but how would this cope with the rest of my setup? I'll be getting a rebuild kit for the bottom end, will I need an expensive one with forged companents? Will the Systemax kit be ok with my block (2-bolt I assume?). What about the stock 4-speed manual 'box and read end? I'm prepared to spend some cash getting this kit and having the engine rebuilt and am not that bothered if it doesn't make near the 400HP they claim when used with the rest of my gear (can upgrade other parts at a later date), but I wouldn't want to spend all this and have the 'box fall apart or shatter the rearend or whatever...
Uriel is offline   Reply With Quote
Reload this Page Bolt-On Horsepower?
Tags
1975, 1999, 2000, 2001, 350, bolt, bolton, c4, corvette, engine, horsepower, hp, l48, ls1, power
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Moderate bolt on horsepower? MyBlueC5 C5 Forced Induction/Nitrous 13 09-05-2004 07:32 PM
bolt on mods no effect on my 94 c4 khalid C4 Tech/Performance 31 05-05-2004 08:13 AM
137 K miler 85 L-98 with bolt on's goes 11.91..... mike 1985 C4 Tech/Performance 25 09-08-2003 06:07 PM
Please assess my plan for a mid 11 sec, reliable, bolt on 03 Z06 Mopar Jimmy C5 Tech 32 05-04-2003 06:28 PM
IS IT TRUE 2001 Z06 MANIFOLDS WILL NOT BOLT ON TO 97-2000 LS1? batsallover C5 Tech 11 11-18-2002 03:11 PM
Performance of bolt-on Vettes. big dave C4 Tech/Performance 14 01-07-2002 03:29 PM
Has anyone installed this intake? Bolt on 50 hp. jimbjr C5 Tech 20 08-25-2001 01:33 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
