Can you get timing cover off with engine in car?
Old 08-03-2004, 05:53 PM
Blue70
Blue70's Avatar
Default Can you get timing cover off with engine in car?
My car is leaving the shop Wed one way or the other!! I'm having problems with the crossfire on my 82. If it's not running right when I take it, I am going to swap to a carb. If I am going to go through all the trouble with swapping over to a carb I am going to change my camshaft too, so I can wake this thing up a little.
My question is, I will be swapping the cam with the engine in the car. Will the oil pan drop enough to get the timing cover off?
With my Roadrunner I could take the oil pan out of the car without touching anything but the pan bolts..somehow I don't think the Vette is going to be that easy
Old 08-03-2004, 05:55 PM
The Dude
The Dude's Avatar
Yes. But you'll be pulling the radiator--or at least unbolting it at the top and pivoting it forward--to R&R the cam. Have fun.
Old 08-03-2004, 06:23 PM
shoptek
shoptek's Avatar
If I recall correctly, I had to remove the idler arm link in the steering rod to get the linkage to drop enough for the pan to drop an extra 1"
Old 08-03-2004, 06:26 PM
Gordonm
Gordonm's Avatar
That is true. Unbolt it and let it hang and you should have enough clearance to get the pan out.
Old 08-03-2004, 08:06 PM
Mr.Gearhead
Mr.Gearhead's Avatar
Roadrunner? BEEP BEEP... hee hee
Actually, just loosen the pan bolts and the cover will come off once the balancer is removed. I think you are going to have to pull the radiator for this job. Try it first without removing it... but I don't think it is going to clear. Also remember, you going to need to put one back in and you need a straight shot as not the "hit" the cam bearings!
Old 08-03-2004, 08:17 PM
Blue70
Blue70's Avatar
Thanks Guys
Roadrunner..BEEP..BEEP..Vroom
Old 08-03-2004, 09:49 PM
GDaina
Support Corvetteforum!
GDaina's Avatar
What about emissions? Do you get tested?
Old 08-03-2004, 10:03 PM
Blue70
Blue70's Avatar
Not yet.
I hear they are going to start in 2006, but only OBDII cars. I'm safe for now
Old 08-03-2004, 10:42 PM
72rdstr
72rdstr's Avatar
I R2'd the cam in mine in the car. Had a leaking pan gasket so dropped it too. Did have to drop steering linkage and remove the radiator. Easy 1/2 day job.
Todd
Old 08-03-2004, 11:36 PM
BacaBill
BacaBill's Avatar
Todd
Yep,, what he said
beep beep
Old 08-03-2004, 11:49 PM
JJEXP
JJEXP's Avatar
Tell ya what, I'll drive down there to nc, do the swap, and throw in the cam for free if you'll give me the road runner. Deal?
Old 08-04-2004, 06:06 AM
Blue70
Blue70's Avatar
Ummmmm......No deal
Old 08-04-2004, 08:56 AM
Eds82
Eds82's Avatar
To change the cam in an 82 the radiator will surely need to come out and the A/C evap coil needs to be moved forward just about an inch (just remove lower bolts to move) to have a straight shot at puttung a new cam in. Been there and done that. Timing cover will come off with no problems. Just need to loosen the pan bolts a little to relieve pressure on the timing cover bottom seal.
Ed
Old 08-04-2004, 09:00 AM
Fevre
Fevre's Avatar
I would pull the pan to give a look see for any material that might be in the bottom to give a heads up on any bearings going bad and you can put a 1 peice pan gasket in to avoid leaks.
To Can you get timing cover off with engine in car?
Quick Reply: Can you get timing cover off with engine in car?
