lube u-joints and half shafts
Originally Posted by 75 Hot One
As far as I know, they're still available from GM. All OEM U-joints have no grease fitting.
Originally Posted by Stoge
Are you sure about this? My car has grease zerks on the U-joints, and they have not been replaced since the car left St. Louis in 1979.
I just checked the Corvette Restoration Guide which has more detailed info for different year C3's. It definitely states that 1978-82 Corvettes have no grease fittings on the U-joints. If you got the car new and know the U-joints haven't been changed, it would be interesting to advise NCRS and see what they have to say.
Premium Supporting Vendor
Originally Posted by z3man987
i hear the noises when turning slowly, mainly turning left i believe but some noises when turning right. when the car goes straight, the only other noises i hear are what im sure is the front pass. wheel acting up due to rotor.
Originally Posted by NHvette
VanSteel offers free shipping for forum members.
Not a giant deal on Ujoints, but good on trailing arm assemblies.
Location: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
1 Post
Originally Posted by brystheguy
Cardomain.com is a site where you can put up pictures of your car and others can look at it and leave comments about it. The comments usually say something like this, "Sweet car, come check out my Z-28 sometime." It seems people only leave comments to get comments. You can link to your pictures too for your signature and the like.
want you check out their site so they can get more hits, on there site.
Lot of really nice cars there.
8th Gear
Use spicer, and about that rotor?
mine is an '81 and just had new ones installed which cost me $30 each :ack but the Napa Precision (?) were not holding up// On my half shafts, they stamped the Spicer no. to use: 429 (I think) and ditto on not using zerks.
I too am currently having problems with a new rotor but I believe it could be damage to the hub. the rivets were absolutely horrible to remove...the only way is by step-drilling up to a 3/8 " in the middle. but I hammered on them some before I resigned my self to drilling. Also, could be poor bearing installation, or improper 12 lb. torque and adjustment. Good luck. Jim
St. Jude Donor '04 & '05
If this is the issue, the additive should resolve the noise.
Good Luck!
i just dropped the car off at the place that redid my diff. he said they added the additive but said maybe it did need one more bottle. i guess only one bottle was put in so that advice on 2 bottles sounds good, thanks. ill get back with results.
Results
just got the vette back, turns out there was minor pinion seal leak and it did need another additive bottle. did some tight figures 8s and all is well now. thanks guys.
