TH200R4 Transmission mount question..
Old 07-16-2004, 11:05 PM
GrandSportC3
GrandSportC3's Avatar
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default TH200R4 Transmission mount question..
I'm planning on installing a TH200R4 with my new setup... I wonder if the TH200R4 uses the same transmission mount as the TH400???
Does anyone know what transmission mounts I'll need and where to get them.. I'm looking to get poly mounts...
Old 07-16-2004, 11:10 PM
comp
comp's Avatar
i thought a stock mount worked ????? I'm working on this trans. and a
383 for my truck
Old 07-16-2004, 11:12 PM
GrandSportC3
383 for my truck
I don't know.... I've never installed a TH200R4.. so I don't know if the standard tranny mount would work...
Old 07-17-2004, 12:23 AM
my74ls4
my74ls4's Avatar
I got mine from Bowtie Overdrives. They have both poly and rubber. I suppose they can tell you what style to get or you could order one from them.
Old 07-17-2004, 12:41 AM
comp
comp's Avatar
did it look like a stock mount?????
Old 07-17-2004, 09:07 AM
mrvette
mrvette's Avatar
A parts house can set you up fine, just get one for a 200 equipped Monte or such,
GENE
Old 07-17-2004, 09:11 AM
GrandSportC3
GENE
Old 07-17-2004, 10:00 AM
redwingvette
Support Corvetteforum!
redwingvette's Avatar
Stock mount is the same.
Old 07-17-2004, 10:58 AM
isosceles
isosceles's Avatar
Cool Oliver!
Looks like there will be 2 C3's sporting 2004r's at the challenge. Yours will be just a tad faster. But I might have an advantage of not having to worry about traction. That helps with consistency.
Hmm, now that the C5 is gone, will you bring the 68 to Bradenton?
Old 07-17-2004, 12:12 PM
GrandSportC3
Originally Posted by isosceles
Cool Oliver!
I'll bring the C3 to Bradenton as soon as the conversion is finished...
BTW - traction won't be an issue for me... Got my new ET Street slicks
(BTW - the tire on the right in the first pic is my old tire size )
Old 07-17-2004, 05:28 PM
Hershey
Hershey's Avatar
Yes, you can use the th400 mount. I just took the trans mount and the shift linlage off of my TH400 and transferred to the 200R-4 and put it in the car. Hershey
Old 07-17-2004, 06:14 PM
GrandSportC3
Well - I have a Tremec TKO 5-speed in the car right now.. I can't use the tranny mount from the TKO.. but I can just get a regular TH400 transmission mount and it'll work!!
Old 07-17-2004, 07:38 PM
AGVI
AGVI's Avatar
Canadian Events Coordinator
Why do people call you Oliver? Isn't your name Olivier or something?
Mungiecakes!!!
Old 07-18-2004, 12:02 AM
GrandSportC3
Mungiecakes!!!
Well - my real name is Olivier.. but I prefer to be called Oliver...
To TH200R4 Transmission mount question..
Quick Reply: TH200R4 Transmission mount question..
