Rear coilovers are done
Old 06-28-2004, 11:39 PM
Schmucker
Schmucker's Avatar
Default Rear coilovers are done
I'm basically ready to drive the car once I fit the exhaust, except now the brakes decided not to work, it's always something. I took a few pics of the rear coilovers. The car sits nice. Needs to settle a little but I'm pleased. A new crossmember was made with intergrated shock mouts. The stock one just doesn't have the necessary clearance, beside it being too heavy. The differential was also raised up closer to the fiberglass. The geometry works better with the car sitting lower.
mirror
http://csagent.homestead.com/files/c...ersdone001.jpg
http://csagent.homestead.com/files/c...ersdone002.jpg
http://csagent.homestead.com/files/c...ersdone003.jpg
http://csagent.homestead.com/files/c...ersdone004.jpg
And the thread about the front
http://forums.corvetteforum.com/zerothread?id=794920
[Modified by Schmucker, 10:27 PM 6/29/2004]
Old 06-28-2004, 11:44 PM
Bryan52803
Bryan52803's Avatar
Default Re: Rear coilovers are done (Schmucker)
Wow, NICE!!
But one question, is the coil-over bracket connected to the trailing arm? If so where's the spring going to go?
Bry
Old 06-28-2004, 11:54 PM
vincevette78
vincevette78's Avatar
Default Re: Rear coilovers are done (Bryan52803)
I like that. Let us know how it works. Is this something you bought or did you make it? Thanks Vince
Old 06-29-2004, 12:05 AM
Schmucker
Schmucker's Avatar
Wow, NICE!!
Bry
The spring is on the shock.
My dad and I made it. No kit.
Old 06-29-2004, 12:07 AM
Bryan52803
Bryan52803's Avatar
Ahh, me = inside the box, and really tired.
So the two springs replace the mono-leaf spring right? Very nice. Looks great and much cleaner
Bry
Old 06-29-2004, 12:11 AM
MN-Brent
MN-Brent's Avatar
Pretty impressive. I hope it drives great. You could possibly market this if you take the plans to an aftermarket company.
Cool stuff!!
Brent...
Old 06-29-2004, 12:38 AM
aharte
aharte's Avatar
Not to kill the party, but have you actually designed this to handle all the loads properly? At first glance, it doesn't look strong enough. The crossmember deals with some pretty serious stresses. Even if it holds together alright, it could flex enough to make the rear end unstable in certain situations.
Old 06-29-2004, 01:10 AM
Schmucker
Schmucker's Avatar
Default Re: Rear coilovers are done (aharte)
It's actually much thicker than it needs to be. It's bolted to the frame at three locations on both sides. The front pinion snubber is also solid mounted.
Old 06-29-2004, 05:32 AM
StingrayDK
StingrayDK's Avatar
Very
Sounds so complicated and you make it look so simple
Old 06-29-2004, 06:09 AM
Twin_Turbo
Twin_Turbo's Avatar
Default Re: Rear coilovers are done (sting74)
I like it a lot, looks like you used part of a competition engineering 4 link rear coil over setup???
Only thing I do not think will hold up is the bracket bolted to the arm and only on the top. I would have welded it or at least use a bolt on the top and bottom, you could easily weld a new plate on it and use the spring bolt pocket for a bolt hole.
What the hell happened to the diff cover?
[Modified by Twin_Turbo, 5:30 AM 6/29/2004]
Old 06-29-2004, 06:56 AM
matchframe
matchframe's Avatar
Is the bottom of the shock mount below the tire rim?
If so, what if you have a flat tire? That could make for an interesting ride!
Could be the opportunity to get some new 20 inch rims w/ low profile tires!
www.bigdogvettes.com
Old 06-29-2004, 07:00 AM
Pauld
Pauld's Avatar
Nice job
Old 06-29-2004, 07:09 AM
OkeeGuy
OkeeGuy's Avatar
very interesting...i like this idea...
however, i too am concerned about the strength of the brackets and how low it seems to be in relationship to the rim...
Old 06-29-2004, 07:15 AM
SmokedTires
SmokedTires's Avatar
Cruise-In III Veteran
St. Jude Donor '05
Default Re: Rear coilovers are done (SIGNGUY)
Very nice !
Old 06-29-2004, 09:07 AM
norvalwilhelm
norvalwilhelm's Avatar
I am glad to see you finish the coil overs all around. I never read about how the fronts turned out, just the post on installing them.
I am anxious to see how you like them once the car is back on the road.
You took a different approach then what I did. I put mine in the stock location.
I like the idea you had about raising the rearend housing. That is always a good thing but watch drive shaft angle s. You could get vibration.
I also would worry about your shock mount where is bolts to the trailing arm. It look pretty flimsy, One thing your springs are easy to adjust. Mine are not quite at easy.
Good luck with them Schmucker and keep us informed.
Old 06-29-2004, 11:03 AM
Stewart's74
Stewart's74's Avatar
Default Re: Rear coilovers are done (norvalwilhelm)
The dreaded red X's
Old 06-29-2004, 11:06 AM
norvalwilhelm
Default Re: Rear coilovers are done (Stewart's74)
The dreaded red X's
What is the dreaded red X's???????
To Rear coilovers are done
Old 06-29-2004, 11:22 AM
Fevre
Fevre's Avatar
The dreaded red X's
When pics won't load properly you get an image outline (like a frame) and a red 'x' in the frame, usually small and in the upper left corner.
Old 06-29-2004, 01:19 PM
Schmucker
Schmucker's Avatar
Default Re: Rear coilovers are done (Twin_Turbo)
Just bought lower shock mounts and used the brackets but not the bracket to hold it to an axle tube. That was only used as a template for this bracket. What is hard to see is that the the bracket that holdes the lower shock mount is actually angle iron. It also has a 3/8th bolt on the side as well as the 1/2 in bolt on the top. A washer was machined down to size the top hole down to 1/2 in so it has a tight fit there. Then there are large washers to help distribute the load across. If it doesn't work, I'll fix it. The previous owner had the rear end fluid changed. My guess is that the shop that did it had to take the rear spring off to remove the cover and it broke. Instead of putting a new cover on, they made a wonderful attempt to weld cast iron. When I went to take off the spring the ears broke. I really didn't feel like putting a new cover on, so I just put coilovers on instead.
In the pictures that is as far down as the half shafts can go. Ride height has them sitting close to horizontal with only a slight downward angle.
The shock mount is actually just slightly higher than the strut mount as well as being further in. So the strut mount would be an issue first. I think more people have their monoleaf closer to the tire than this is.
I'd have some driving impressions but my master cylinder decided to die while the car sat.
Old 06-29-2004, 04:16 PM
NHvette
NHvette's Avatar
Arghhh - red Xs - looks like your exceeded your homestead traffic quota.
I'll have to look later.
Quick Reply: Rear coilovers are done
