Steering Question
Old 05-18-2004, 04:55 AM
OBL1V1ON
OBL1V1ON's Avatar
Default Steering Question
This is probably a stupid question. Anyhow, i just replaced my oil pan gasket, and to do that i had to drop the center link and unhook my steering cylinder and the fluid drained out. When i put it all back together do i just fill up the fluid and go or do i do some kind of bleeding like when you bleed your brakes?
Old 05-18-2004, 07:42 AM
71coupe
71coupe's Avatar
Default Re: Steering Question (OBL1V1ON)
That's strange, where did the fluid drain out from? I'm always dropping that when I pull the pan and never get a leak (not counting the steady leak it already has :lol: )
Old 05-18-2004, 11:34 AM
OBL1V1ON
OBL1V1ON's Avatar
Default Re: Steering Question (71coupe)
Well it probably would not have leaked, but i disconnected the lines in and out.
Old 05-18-2004, 12:19 PM
Edzred72
Edzred72's Avatar
Fill the tank and leave the cap off for air to escape system. Turn the steering wheel lock to lock a few times. Refill the tank leaving the cap off. Start car...turn steering wheel lock to lock again. Check fluid...replace cap....do a burnout!!! The last part is very important :D :yesnod: :D :yesnod: After driving it around a bit...check fluid again. Should be good to go
Eddie
[Modified by Silvr77, 11:21 AM 5/18/2004]
To Steering Question
Quick Reply: Steering Question
