I hear a clunk as I am coming to a stop.
Old 04-28-2004, 01:48 PM
bloodvette80
bloodvette80's Avatar
Default I hear a clunk as I am coming to a stop.
every time as i slow down, jsut before coming to a stop theres a clunk. ITs quiet faint, and really have to listen for it. It's been doing this for a long time. I checked my brakes, calipers are tight, could it be transmission? (I can't tell where the sound is coming from), definitely not the rear of the vehicle though. ideas? :confused:
[Modified by bloodvette80, 6:49 PM 4/28/2004]
Old 04-28-2004, 01:58 PM
MEGALADON
MEGALADON's Avatar
Location: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Default Re: I hear a clunk as I am coming to a stop. (bloodvette80)
Is your driveshaft ok? :skep:
Old 04-28-2004, 02:13 PM
Stewart's74
Stewart's74's Avatar
Default Re: I hear a clunk as I am coming to a stop. (MEGLADON)
Its your head hitting the steering wheel :jester
Might want to have the tranny looked at. U-Joints can also be suspects.
Old 04-28-2004, 02:15 PM
Augie 79
Augie 79's Avatar
Could be a-arm bushings.
Old 04-28-2004, 02:40 PM
75Rag
75Rag's Avatar
Default Re: I hear a clunk as I am coming to a stop. (Stewart's74)
Seriously ..... do you have a socket or something (lug nut socket) rolling around in the glove box or storage area? ....... I know that sounds stupid but it's worth checking before all the other stuff ........
Old 04-28-2004, 03:07 PM
Packy76
Packy76's Avatar
how about the differential bushing? Just replaced mine ..there was nothing left of it It was the top one that you cant see but if you feel around with you fingers you can feel some of the rubber desintegrated
Old 04-28-2004, 03:10 PM
Pete76Shark
Support Corvetteforum!
Pete76Shark's Avatar
Default Re: I hear a clunk as I am coming to a stop. (75Rag)
Also dont forget to look under the storage area where the flat tire jack is. I has something in there that was causing a noise..
Old 04-29-2004, 11:30 AM
bloodvette80
Default Re: I hear a clunk as I am coming to a stop. (Pete76Shark)
it is definitely coming from the front of the vehicle, most of the time the clunking is not from my head hitting the steering wheel or the windshield. I will check out the control arms, but I feel it something to do with the drive train, since it happens on deceleration.
I think its the nut holding the steering wheel. :lol:
Old 04-30-2004, 01:03 AM
Turbo-Jet
Turbo-Jet's Avatar
does it happen on deceleration or braking? at what % of full stop does it make the noise? does speed make a difference?
Old 04-30-2004, 07:44 AM
Ybnormal
Ybnormal's Avatar
I have a automatic Jeep that does the same thing, a faint clunk as the transmission downshifts to first gear. Sometimes it will not do it until after you stop and let off the brake to inch forward. Mine is for sure in the transmission, sounds similar to what you describe. If so I would check the tranny...just my 2 noncents worth.
YBnormal...drive a vette
Old 04-30-2004, 01:46 PM
bloodvette80
Default Re: I hear a clunk as I am coming to a stop. (Ybnormal)
It happens on braking only, but just about at stop, meaning, if I don't apply the binders, it won't do it, becuase it won't stop. I think your on to something that it does it on a downshift. I will try leaving it in first geat (automatic Trans) get up to a good speed, below redline obvisouly, and then come to a stop see if it does it, if not, obvisouly the sound is the downshift to 1st in the tranny.
To I hear a clunk as I am coming to a stop.
Quick Reply: I hear a clunk as I am coming to a stop.
