Q-jet inlet repair
Q-jet inlet repair
Anybody know a way to repair the female threads on the gas line/filter inlet on a Q-jet. Mine have been stripped for the past few times I've changed the paper filter, but this time the fitting won't even snug to a point where I'm comfortable with it. Thinking about not even installing the small filter and JB Welding it in place. But, knowing me, even if I JB Weld her in there I'll need to fix it right in the near future. So, thinking as I'm typing I guess I'll install the filter AND permanently epoxy the fitting in.
But, in the mean time (and for future reference) does anybody know how this white metal threaded inlet can be fixed? Adapter bushing, oversized male fitting, etc?
Re: Q-jet inlet repair (ettev)
I would stay away from epoxy. I have heard a Heli-coil fix is available,but the tooling is cost prohibitive. Why not send it to Lars and let him do the repair. I understand he has the tooling for it plus a jig to hold the carb base when he bores out the old threads.He can be reached at V8FastCars@msn.com .I have had my carb. and dist. done by him and was very pleased with his work and turn around time. JW714 :thumbs:
St. Jude Donor '05-'06
I had mine rebuilt by recarbco out in california. They repaired all the threads and put in bushings along with the plating and bench flow testing the carb. Looks like brand new for $127 + $15 shipping. If your carb was in good condition except for the threads I would send it to LARS as he is the QJET guru. Mine was a piece of crap of ebay so I sent it to recarbco for the total rebuild. I may send it to LARS to tune in the next year once I get the rest of my stuff organised.
[Modified by stingry, 2:19 PM 4/17/2004]
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,927 Likes
I can properly repair the early model Q-Jet inlet threads (the 7/8" threads). JB weld isn't going to hold, and it will start leaking when you don't know it's leaking.... I've seen cars burn to the ground like that.
Re: Q-jet inlet repair (lars)
[Modified by ettev, 10:34 AM 4/19/2004]
Re: Q-jet inlet repair (UKPaul)
Paul
Made by Motormite. Found their website: http://www.motormitedormancatalog.com/start.wws
From website, No. should be:
55141 1" dia. w/long fitting to accept filter Quadrajet
55140 1" dia. w/short fitting for Quadrajet
[Modified by Ganey, 9:01 AM 4/20/2004]
Re: Q-jet inlet repair (MNJack)
That's why it said "should". It's always better to check than call. You could have given a link. Thanks for the help. He probably needs it to find, being in the UK.
Previous post edited w/ new info. from their website.
Re: Q-jet inlet repair (Ganey)
I've never had much success with those over-sized self-tapping repair inlet fittings. The problem is that when the threads strip out, the metal in the inlet area turns into this gray-colored mush. The oversized thread-tapping fittings don't dig in deep enough to cut a good, reliable thread: they dig in far enough that you can get the new fitting installed and working, but after a couple of removals, the threads strip right back out again. The only way to really repair the inlet is to tap it into clean virgin metal and install a stainless steel helical insert. That way, the inlet fitting will ride on the stainless threads and not rely on the "pot metal" threads for the wear.
Ganey,
Thanks for the link, excellent info :thumbs: I've used that type of fix before, in a different situation & as long as you're careful putting it in you can usually fix the problem (depending on how heavy-handed Bubba was in wrecking it in the 1st place). As Lars rightly said, you can't take them back out very often & still keep a good seal.
Lars,
Here's what the situation is: I've got the inlet adaptor in as tight as I dare. Any tighter & it'll probably rip out the last of the thread from the monkey metal the carb is made of. The filter has been removed & I'm running an external one. I'll get one of the parts Ganey has pointed me to, but won't fit it unless it starts leaking. At the moment there is a yellow stain slowly spreading, so it's obviously seeping slightly, but there's only a miniscule amount of fuel getting out as it's never wet. I know that you'll turn around the fix quickly but the postal system isn't as efficient (not to mention any hang-ups in Customs). If it leaks & the part Ganey pointed me to doesn't fix it then I'll send it to you for a repair, otherwise I'll send it at the end of the summer (if I'd thought about it I should have done this during the winter :kickingmyself!).
By the way, your recommendation for DA secondary rods with my Dynomax Headers was spot on, it runs great with them :thumbs: Nice one mate! (Or as we used to say, "Much obliged old chap, thanks awfully"!).
Thanks both of you,
:cheers:
Lars,
Thanks both of you,
:cheers:
It didn't look like removing it repeatedly for filter replacement would last, that's why:
I changed the guy's carb setup to an external filter.
He's had no problems w/ it.
