Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-25-2004, 10:07 PM   #1
David68
CF Senior Member
Support Corvetteforum!
Default Vortec intake & thermostat bypass?
After extensively searching for the topic I need, without success, I've come for help. Several weeks ago there was a post detailing why the vortecs need to have the hose from the vortec intake to the water pump. I'm to that point now and would like a repeat of that post or a link. There was reference to this arrangement being on the big blocks and even a picture of someone having done this. The alignment from the intake to the pump is not a straight shot and I'm curious how others have plumbed this. Any help and guidance is appreciated.
David68 is offline   Reply With Quote
Old 02-26-2004, 11:34 AM   #2
David68
CF Senior Member
Default Re: Vortec intake & thermostat bypass? (David68)
Anybody?? :confused:
Old 02-27-2004, 10:13 PM   #3
David68
CF Senior Member
For the weekend view.
Thanks.
Old 02-28-2004, 02:06 AM   #4
pillowmeto
CF Senior Member
pillowmeto's Avatar
Send a message via AIM to pillowmeto
:lurk:
pillowmeto is offline   Reply With Quote
Old 02-28-2004, 08:29 AM   #5
American Boy
CF Senior Member
American Boy's Avatar
Hi,
I can't find the link either but I was a part of it so I'll explain from what I remember. Here is the pic:
Click the image to open in full size.
I didn't take pic of the rubber hose attach and my car is away for the winter. What I did was to put fitting in the intake and water pump and then I did a model of the hose that I needed (with metal wire). I went to the part store and ask the guy at the counter to find me something that would look-a-like. He found one, it was around 1/2'' dia if I remember correctly. I had to cut a little lenght but it was a close fit. The hose start at the water pump straight up, does a 90 degrees to the horizontal and then another 90 degrees toward the intake fitting.
Good luck
Stephan
[Modified by American Boy, 8:36 AM 2/28/2004]
American Boy is offline   Reply With Quote
Old 02-28-2004, 09:47 PM   #6
David68
CF Senior Member
Default Re: Vortec intake & thermostat bypass? (American Boy)
Thanks Stephan. That's one method I'll look into.
Old 02-29-2004, 01:24 PM   #7
Older Than Dirt
CF Senior Member
Older Than Dirt's Avatar
I have a ZZ430 with a Edelbrock Air Gap Vortec intake. My intake has these same provisions. What is the purpose of a hose directly from the intake to the top of the water pump?
Older Than Dirt is offline   Reply With Quote
Old 02-29-2004, 06:15 PM   #8
American Boy
CF Senior Member
Default Re: Vortec intake & thermostat bypass? (Older Than Dirt)
The heads are missing a hole that allow the cooling circuit to by-pass the thermostat from the water pump through the passenger side head and intake. That hole prevent pressure build-up during warm-up. In other word, if you don't have it, pressure will prevent thermostat to open until the engine get really hot (read in the red).
Stephan
Old 02-29-2004, 07:25 PM   #9
chewy
CF Senior Member
Strange I don't have one hooked up. Absolutely no trouble. I am using a short water pump that doesn't have any provision for a top hose fitting.
chewy is offline   Reply With Quote
Old 02-29-2004, 09:32 PM   #10
neverendingproject
CF Senior Member
Default Re: Vortec intake & thermostat bypass? (chewy)
from what i have been told, this only needs to be done on 86 and newer blocks. supposedly the passage is in the block , not the heads. i dont know for sure though.
found where i read it at. my intake instructions.
cant copy and paste , so i'll quote.
"This intake manifold is primarily intended for use with Vortec heads on pre-Vortec blocks. Standard engine blocks route thermostat bypass water from the block directly to the water pump through the passenger side water pump mounting flange. If the manifold is used on a 1996 and later Vortec engine that does not have the in -block bypas passage, you must route a thermostat bypass hose from the water bypass port on the front of the manifold to the 5/8" hose nipple on the passenger side of the Vortec water pump. Use a 3/8" pipe to 5/8" hose nipple fitting, and a 7" length of 5/8" hose to accomplish this. If your engine block has the thermostat bypass passage, use the 3/8" plug supplied in the kit to plug the bypass port in the front of the intake manifold."
[Modified by neverendingproject, 2:57 AM 3/1/2004]
neverendingproject is offline   Reply With Quote
Old 02-29-2004, 11:16 PM   #11
American Boy
CF Senior Member
Default Re: Vortec intake & thermostat bypass? (neverendingproject)
I have a 1996 vortec block so in my case, the passage wasn't there. I didn't check if the heads had the passage, so it could be the block that causes that problem.
Stephan
Reload this Page Vortec intake & thermostat bypass?
Tags
block, blueprint, bypass, carb, diagram, engine, external, hole, hose, intake, intakes, pump, thermostat, vortec, water
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
