Power lock problem still presists..
Old 02-26-2004, 12:14 PM
82Powerhouse
82Powerhouse's Avatar
Default Power lock problem still presists..
1982 Corvette
I am still having trouble finding the source of the power lock problem. It will lock, but not unlock. It is acting like there is a relay that is bad, but I can not find it. It looks like the wires go to the back of the fuse box, but there is not a relay there.
On the switch, there are 5 wires: orange, grey, blue, brown, and black. The orange and grey work (lock), but the blue and brown (unlock) do not work. If I put a piece of metal across the blue and brown and then hit the switch, it works. If I leave it crossed, it smokes of course. This is why it seems there is a relay to switch between the orange and blue wires. It is the brown and gray that go into the actuator. Any advice on this would be greatly appreciated. I can not put the interior in, until I get this part done.
TIA,
CDM
Old 02-26-2004, 02:19 PM
DennyM
DennyM's Avatar
Default Re: Power lock problem still presists.. (82Powerhouse)
I would think that you only have one solnoid that operates the lock/unlock mech.in each door When you jump the wires you are in effect bypassing the switch. I would check the switch with a ohmmeter to see if you have continuity thru the switch in the unlock position. Then check the wires with a test light to see that the current is being sent to each solonoid on each door
Old 02-26-2004, 02:38 PM
Sean82
Sean82's Avatar
The power locks are run off the passanger side.
Take the passenger side door panel off and check for a loose connection at the swith.
Make the passanger side work first and then the driver side should work.
To Power lock problem still presists..
Quick Reply: Power lock problem still presists..
