You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Getting ready to install my quadrajet on my 350. Does anyone have a vacuum diagram as to what vacuum port goes to what component? I have a diagram for the A/C, wiper, and headlight vacuum systems, but what I don’t have is a proper connection diagram or instructions for the other vacuum systems like the vacuum advance, automatic transmission vacuum, and power assisted brakes. Getting down to the last of the installation process, won’t be long now!
Thanks for the replies. I have a Carter QJ # 7040202 off of a 1970 350/300. On all of the diagrams it shows a vacuum port to the right, (looking at the front of the carb) of the fuel inlet. Mine does not have such a port. There is one above and to the left of the fuel inlet right above the choke pull off port, and a hole in the carb’s base located just to the right of the PCV port. On the left side of the carb sticking out through the choke pull off metal frame is a long vacuum port. The only other ports/holes in the carb is in the rear top. It is just a hole, but is open and free for air to flow. All of the above is assuming that you are looking at the carb from the front. Is my carburetor just different, or is it typical for that year?
