Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-13-2004, 10:57 PM   #1
tom102
CF Senior Member
tom102's Avatar
Default How do you check an Ammeter (Battery Gauge) before installing?
I just picked up a used ammeter to replace the dead one in my 76 vette. Before I tear the dash and bezel apert to install it I would like to make sure it works ok. We just put an ohmeter across the two terminals on the back of the ammeter and show continuity between the two terminals can I safely assume the meter is good? Or is there another way of testing it out?
[Modified by tom102, 7:00 PM 2/14/2004]
tom102 is offline   Reply With Quote
Old 02-14-2004, 10:10 AM   #2
vettemack
CF Senior Member
vettemack's Avatar
Send a message via AIM to vettemack
Default Re: How do you check an Ammeter (Battery Gauge) before installing? (tom102)
DO NOT PUT AN OHMMETER ACROSS THE TERMINALS!!! It will peg the meter and damage it.
The meter movement is usually a very low current, 50microamps/500microamps, or so. That is 50/1,000,000 amps.
You would need the shunt off your old meter to test correctly or a current output of 0-50 ua. This would be hard to find unless you were involved in test equipment calibration or have a friend in that business.
vettemack is offline   Reply With Quote
Old 02-14-2004, 10:55 AM   #3
ettev
CF Senior Member
ettev's Avatar
Default Re: How do you check an Ammeter (vettemack)
:eek:
The guy that rebuilt mine at Corvettes at Carlisle checked all his with an ohm meter. I can't imagine a check like that for anly a fraction of a second would hurt the meter.
ettev is offline   Reply With Quote
Old 02-14-2004, 06:59 PM   #4
tom102
CF Senior Member
tom102's Avatar
When I recieved the ammeter the fellow that had it put an ammeter across the terminals to show me it was working and it did show continuity however the needle on the gauge did not move at all when he did that. I thought that was ok as no electric was being applied to it. Was I wrong in assuming this?
[Modified by tom102, 7:01 PM 2/14/2004]
Old 02-14-2004, 07:14 PM   #5
JOliver
CF Senior Member
JOliver's Avatar
Send a message via AIM to JOliver
Default Re: How do you check an Ammeter (tom102)
You're correct
You can use an ohmmeter on it without any problems...You can even take a power supply or a battery and tap it just for a second to see if it jumps.
I have the proper equipment to do this with but a small power supply with a breaker is ideal....And there is No shunt resistor on a battery gauge.
VetteInstruments@aol.com
Jason
JOliver is offline   Reply With Quote
Old 02-15-2004, 12:30 PM   #6
tom102
CF Senior Member
tom102's Avatar
Default Re: How do you check an Ammeter (JOliver)
Can I use my 12v battery charger to test the meter function by hooking the positive side to one of the terminals and the neg lead grounded on the case of the meter? or is this a fast way to burn up the gauge. Like I said there is continuity across the terminals. I am not that good with electrical stuff and tend to burn things out thats why I am asking
Old 02-15-2004, 02:05 PM   #7
Mike Ward
CF Senior Member
Mike Ward's Avatar
Location: about an hour away from Paul74 in Ontariariario
Even easier and safer is using a 1.5 volt flashlight battery. Just touch the contacts for a brief millisecond to see if the gauge needle moves.
Mike Ward is online now   Reply With Quote
Old 02-15-2004, 02:15 PM   #8
turtlevette
CF Senior Member
St. Jude Donor '03-'11
turtlevette's Avatar
Default Re: How do you check an Ammeter (Mike Ward)
YES, Thats what i would recommend. Shorting across a car battery or charger is not a good idea, you are going to get a 400 amp punch out of a car battery which can damage the meter. You may damage your battery charger by shorting it through the ammeter.
An ohm meter to show continuity is a good test too. The guy who thinks you are going to damage the ohm meter is wrong.
[Modified by turtlevette, 2:16 PM 2/15/2004]
turtlevette is offline   Reply With Quote
Old 02-15-2004, 04:10 PM   #9
KenSny
CF Senior Member
KenSny's Avatar
I agree: Use a small AAA battery and QUICKLY touch the gauge terminals and the needle should swing one way, then reverse the leads and the needle should swing the other way. This will NOT destroy a working meter.
KenSny is offline   Reply With Quote
Old 02-15-2004, 07:48 PM   #10
tom102
CF Senior Member
tom102's Avatar
Default Re: How do you check an Ammeter (KenSny)
Thank all of you for your help :) I tested the gauge using a AAA battery with a momentary contact on the terminals of the gauge and the needle moved in one direction then reversed the contact points and the needle moved the other way. Now I can take the dash gauge bezel out of the car to install what I know is a working gauge. Thanks again for the help.
[Modified by tom102, 7:49 PM 2/15/2004]
Reload this Page How do you check an Ammeter (Battery Gauge) before installing?
Tags
76, ammeter, amp, battery, c3, car, charger, check, continuity, corvette, gauge, installing, meter, pegs, show, terminals, working
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
