Anybody running DART IRON EAGLE heads?
Old 02-03-2004, 01:25 PM
Stewart's74
Stewart's74's Avatar
Default Anybody running DART IRON EAGLE heads?
I'm looking at a set of Dart Iron Eagles.
180 intake runner / 72 CC. 2.02/1.60 valves.
They look lika a descent pair of heads to me.
Opinions please.
Old 02-03-2004, 02:40 PM
gdh
gdh's Avatar
Default Re: Anybody running DART IRON EAGLE heads? (Stewart's74)
I have the 200's that were also race ported - they are great heads especially given their price.
Old 02-03-2004, 02:51 PM
burners
burners's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
I have a set of 215's with 2.05 valves and angle plugs on my 1970 Nova and I love them. They are very nice. The casting quality is impressive and the overall design is equally impressive. If you are running flat top pistons I would go with 64cc chambers and smooth them to get maybe 66cc. That should give you a good compression ratio without getting too high. My heads actually finished out to about 68cc so I recommend starting with the smaller chambers unless you have dome pistons.
Old 02-03-2004, 03:31 PM
Solid LT1
Solid LT1's Avatar
Default Re: Anybody running DART IRON EAGLE heads? (burners)
Unless you are running a 383 or 400 stay with your 180cc heads GOOD DECISION! they will have better low end torque and still be right there in HP terms up to 7000 RPM compared to the bigger port DARTS. I do not have a set of the latest Iron Eagles but I do have a early never used set of Dart Sportsman heads with 180cc intakes (angle plug heads 72cc chambers) but the Iron Eagles do have a better exhaust than the early Dart heads (new eagles can make 12-18HP more than older versions with the right cam selection), they are yours for a reasonable price if you want them, pocket ported and ready to run: $695 assembled with SS 2.02/1.60 valves, screw in studs/guide plates, new 1.44 dia flat tappet springs, chrome molly retainers and MACHINED locks (only use machined locks on HP stuff!) Email me if you are interested, I can send you photos. zeohsix2002@hotmail.com
[Modified by Solid LT1, 12:32 PM 2/3/2004]
Old 02-03-2004, 03:50 PM
A78Corvette
A78Corvette's Avatar
Default Re: Anybody running DART IRON EAGLE heads? (gdh)
I was thinking of buying Dart heads. Where can they be bought the cheepest? Dart told me by phone that they won,t sell to an individual. I can buy Motown heads from summit or Jegs, but are they as good as Dart heads?If they are why are Dart heads so popular? any advise would be most welcome. :conehead :confused:
Old 02-03-2004, 04:44 PM
marshrat99
marshrat99's Avatar
I'm running the 180 Dart IE's but with a 64cc chamber. So far they've been great. IMO, a good choice for the money. :cheers:
Old 02-03-2004, 05:04 PM
Fevre
Fevre's Avatar
Pony up another $150 and get some alum trick flow heads with much better flow and weigh a lot less:
Trick Flow
Iron Eagle $900/pair:
If flow jpg's don't appear look here:
http://www.chevyhiperformance.com/techarticles/41598/
You should be abel to run some 1.6 rockers and get up to about .484 lift too.
[Modified by Fevre, 5:10 PM 2/3/2004]
Old 02-03-2004, 05:11 PM
Eric R
Eric R's Avatar
Default Re: Anybody running DART IRON EAGLE heads? (Fevre)
Bought a set and love 'em 200cc/72cc
Old 02-03-2004, 05:31 PM
catchme76
catchme76's Avatar
Default Re: Anybody running DART IRON EAGLE heads? (Eric R)
I am about to sell mine(200cc) 2.02, 1.6. flow good enough to put me 13s pretty deep.
Old 02-03-2004, 06:55 PM
A78Corvette
Thanks for the link Fevre. I can read up before i spend any money. :conehead
Old 02-03-2004, 07:05 PM
Blue70
Blue70's Avatar
Have a pair of 200cc 64 chamber on my 70 Camaro :cool:
Old 02-03-2004, 07:43 PM
GrandSportC3
GrandSportC3's Avatar
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I have DART IRON EAGLE with 215cc intake runners and 64 cc chambers.. The 180cc heads are a little small for my taste.. Go with at least with 200 cc to get decent performance..
Old 02-03-2004, 08:18 PM
gdh
gdh's Avatar
Default Re: Anybody running DART IRON EAGLE heads? (GrandSportC3)
you can pick up the I. Eagle bare heads for @$550 check out Gears Are Us or many of the other places on eBay, you can luck into some great deals on new heads if you are lucky and know exaclty what you want.
[Modified by gdh, 8:20 PM 2/3/2004]
Old 02-03-2004, 08:39 PM
munday
munday's Avatar
i'm running 230 runners with a mild race port and 72cc chambers, came on my crate engine....they are :cool:
Old 02-03-2004, 08:52 PM
TedH
Support Corvetteforum!
TedH's Avatar
I'm running the DART 180cc head on my engine (see signature). :seeya
[Modified by TedH, 9:14 PM 2/3/2004]
Old 02-03-2004, 09:04 PM
MotorHead
MotorHead's Avatar
Location: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: Anybody running DART IRON EAGLE heads? (TedH)
Take it from me gdh is making some serious power with the Iron Eagles :D
Old 02-03-2004, 09:15 PM
GrandSportC3
Default Re: Anybody running DART IRON EAGLE heads? (MotorHead)
Very true.. but 180cc runners are not to big.. That's just slightly bigger than stock GM heads... 200+ cc are needed for good performance..
To Anybody running DART IRON EAGLE heads?
Old 02-03-2004, 10:12 PM
Eric R
Eric R's Avatar
This should give you an idea:
http://www.dartheads.com/csbhiron.htm
The 200cc runners seem to be about the best fit for a street performance 350.
Old 02-03-2004, 10:28 PM
TedH
TedH's Avatar
Kind of wish I'd purchased the 200cc heads (or at least this info had been available). Tuner praised the 180cc heads prior to purchase in 2001. Oh well, lesson learned.
Old 02-03-2004, 10:53 PM
78 Vette
78 Vette's Avatar
Trick Flow
Thats what I did
Quick Reply: Anybody running DART IRON EAGLE heads?
