[RANT] SBC Alternator brackets...
Old 01-24-2004, 11:19 AM
carriljc
carriljc's Avatar
Default Mine has the same casting number
Casting number 3951337.
I could have gotten it for $3.50, but I gave my buddy 5 bucks since he picked it up for me up the junkyard....being the giver that I am.
Old 01-24-2004, 12:20 PM
75stinger
75stinger's Avatar
Default Re: [RANT] SBC Alternator brackets... (VetteNut72)
I have one in black on my desk as a paper weight, it's yours if you want it Oliver.
Old 01-24-2004, 11:47 PM
GrandSportC3
GrandSportC3's Avatar
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: [RANT] SBC Alternator brackets... (75stinger)
Thanks for the offer.. but I got myself a nice chrome plated aluminum bracket at the swap meet (at the NCRS show) today.. I already installed it and it looks and works great!! Thanks everyone for the help and input..
I'll try to post a pic of the newly installed bracket tomorrow..
Old 01-24-2004, 11:50 PM
GrandSportC3
Default Re: [RANT] SBC Alternator brackets... (GrandSportC3)
The one that I bought today looked just like the one in the Ebay auction... with the only difference that the one that I bought at the swap meet was chrome plated... I only paid $15 :D :D
It's like this one below.. just chrome plated :
Old 01-25-2004, 12:19 AM
BSeery
BSeery's Avatar
Location: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: [RANT] SBC Alternator brackets... (turtlevette)
iThose modern brackets are way too expensive.. I'm willing to spend up to $100 for something that lasts..
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2455624800
YEP !!
Use that as the lower, and then use the universal adjustable bracket on top. The only problem is that it has to be drivers side mounted (I think).
Old 01-25-2004, 12:34 AM
GrandSportC3
Default Re: [RANT] SBC Alternator brackets... (BSeery)
YEP !!
That's not a problem.. I always had the alternator mounted on the drivers side.. The new bracket really works great!! I'll post some pics tomorrow!!
Old 01-25-2004, 07:38 AM
Twin_Turbo
Twin_Turbo's Avatar
Default Re: [RANT] SBC Alternator brackets... (Steve Straus)
IMO this is the only way to go:
It's a March billet aluminum alternator bracket. It uses a tie rod with two heim joints to adjust the tension. No more prying, just turn the wrench and then tighten the jamb nuts.
It's $165 at Jegs, but honesty, it's worth it. That's not much more than you were willing to spend.
http://www.jegs.com/cgi-bin/ncommerc...11&prmenbr=361
Part Number 655-20130
[Modified by Steve Straus, 10:20 AM 1/24/2004]
I never really like that setup, IMO it looks like a crane with all those beams and stuff.
I have this and it's the best mount I ever had, however it's not for a GM alternator but a small denso/powermaster one.
Old 01-25-2004, 08:29 AM
Fevre
Fevre's Avatar
YEP !!
I am running the alum version of the bracket pictured and I could not use a univeral upper bracket since the angle of the bends are diff, I think the universal one's bend was not as sharp as my orig so it would hit the alt housing before the bolt hole lined up.
Old 01-25-2004, 09:16 AM
GrandSportC3
Default Re: [RANT] SBC Alternator brackets... (Fevre)
YEP !!
I was able to use the universal upper bracket.. but it wasn't all that easy to make it work.. :D :D. I'll go to the car right now to take a pic of the setup...
Old 01-25-2004, 09:37 AM
GrandSportC3
Here are 3 pics of the setup:
Old 01-25-2004, 10:10 AM
no_radio
no_radio's Avatar
Default Re: [RANT] SBC Alternator brackets... (Mark70)
As an option, Summit Racing sells billet aluminum brackets for short and long water pumps for $60 - $70:
SME-2000 Chevrolet: 262-400, long water pump, billet alluminum, alternator bracket $59.95
SME-2001 Alternator Bracket, SBC Short-WP, Driver Side-Cylinder Head Mnt., Satin $69.95
Does anyone have a picture of the Summit bracket installed on the car? This sounds like what I need, but they don't have a picture on their website.
Thanks!
Jeff
Old 01-25-2004, 10:29 AM
Fevre
Fevre's Avatar
GS
Did you haveto drill the hole you are using or was it pre-drilled? That was something I was thinking of but decided to use my old bracket instead. Too bad you can't cut the bracket off near your mounting hole to make it look cleaner but that would f up the chrome.
Old 01-25-2004, 07:42 PM
  #33
garandfan
garandfan's Avatar
CI 5-6-7-8-9 Veteran
Cruise-In 7 Car Show Winner
Frank
Old 01-25-2004, 09:07 PM
  #34
Mark70
Mark70's Avatar
I like the look of the chromed bracket! Looks good and reasonably priced. Is that bracket for a long water pump or the short pump? Looks like I overspent on the March bracket, but it looks nice and mounts the alternator solidly.
Here are some links to the March site:
http://www.marchperf.com/products/21131-bracket_lg.jpg
http://www.marchperf.com/pg8.html#ombrac
I like the heim jointed adjusting rod. It's very easy to adjust belt tension.
Old 01-25-2004, 09:19 PM
  #35
GrandSportC3
GS
It bolted right to the accessory holes in the cylinder head.. Don't know if the stock heads have the same holes.. My heads are DART Iron Eagle heads and they came with the accessory holes...
Old 01-25-2004, 09:21 PM
  #36
GrandSportC3
It's for short water pump.. C3's only came with short water pumps..
Old 01-25-2004, 09:30 PM
  #37
OkeeGuy
OkeeGuy's Avatar
http://www.zip-products.com/Corvette...EA9D2ABD3B58C7
To [RANT] SBC Alternator brackets...
Old 01-25-2004, 10:40 PM
  #38
Smokehouse69
Smokehouse69's Avatar
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: [RANT] SBC Alternator brackets... (SIGNGUY)
I bought one of the aluminum brackets like Olivier showed, it wouldn't work with my ZZ4 accessory holes. :(
Old 01-26-2004, 03:15 AM
  #39
garandfan
garandfan's Avatar
Default Re: [RANT] SBC Alternator brackets... (Smokehouse69)
I don't know why it wouldn't fit on your ZZ4, thats what this is, and it mounted up fine.
Frank
Frank
_______
USMC 1980-1986, SEMPER-FI! 1970 monza red Vert, 1986 bright red coupe. You guys have me hooked!! Gotta love a RED VETE!!
Old 01-26-2004, 12:26 PM
  #40
Kid Vette
Kid Vette's Avatar
Default Re: [RANT] SBC Alternator brackets... (garandfan)
For those of us with no accessory holes in the heads, Jeg's has this bracket (Excuse the ratty looking engine compartment. I'm working on it OK?)
Its "E' on this pic.
Its their PN 289-88301. Sells for $15.99
Quick Reply: [RANT] SBC Alternator brackets...
