Rear end diagnoisis - Wheel bearings or universals ??
To all you corvette proctologists - :lol:
Have noticed a loud squeak squeak when travelling at slow speed coming form the rear left. When going slow no real vibration but travelling at 100kms I get a strong shudder on acceleration and deceleration. When I have a neutral throttle setting the shudder disappears. Im thinking more likely a uj either rear propshaft or driveshaft. :nopity:
Any opinions or similar problems
:cool: :cool: :cool:
Re: Rear end diagnoisis - Wheel bearings or universals ?? (tippi58)
I agree, a wheel bearing would more than likely not be affected by accel or deccel. Although if your wheel bearings are original, they probably are needing replacement.
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Sounds like a u-joint to me. If the squeak-squeak-squeak speeds up and slows down in direct proportion to the speed you are traveling it's most likely a u-joint. You can check each for any play by twisting by hand back and forth (any play is reject). It's not all that big of a job to replace them, having a oxy/acetylene torch helps a lot, those things really get socked in tight after 25 or 30 years.
[Modified by Big Fish, 11:40 PM 1/12/2004]
Premium Supporting Vendor
Re: Rear end diagnoisis - Wheel bearings or universals ?? (Big Fish)
I'm thinking u-joint also but on the driveshaft b/c of the vibration. Also check your trans mount.
I had the squeak, squeak, and it turned out to be the r/wheel bearing :cry the bearing was completly gone, its off to Van Steel :smash: bushog
Re: Rear end diagnoisis - Wheel bearings or universals ?? (petty44)
Cheers Guys, I took it out for a short run today and am pretty sure its the uj.
:rofl:
Thanks for the trans mount tip, I will check that tonite. :smash:
:rofl:
