Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-11-2004, 11:25 AM   #1
Larsson
CF Senior Member
Larsson's Avatar
Send a message via ICQ to Larsson
Default th400 speedometer cable leak
Have the car up on jackstands right now and I've found that the place where the tranny leaks most is from the speedometer cable. Now I wonder if there's anything special I should think about before I start. The transmission is still in the car btw.
I suppose there is some kind of gearwheels behind the cover, anything special I should think about when I take the parts apart and put them together again?
I've searched the archives but found nothing detailed about changing these gaskets.
Larsson is offline   Reply With Quote
Old 01-11-2004, 11:29 AM   #2
GTR1999
CF Senior Member
Default Re: th400 speedometer cable leak (Larsson)
I can check the th400 I have but the Muncie and ST-10 trannies use a O ring on the sleeve for the speedo gear in the housing. I think the TH400 is the same too?
Gary
GTR1999 is offline   Reply With Quote
Old 01-11-2004, 02:38 PM   #3
redwingvette
CF Senior Member
redwingvette's Avatar
Send a message via AIM to redwingvette
Default Re: th400 speedometer cable leak (gtr1999)
There is an O-ring on the sleeve and a seal on the inside that rides on the gear. Both parts can be found at most parts stores. You will want to check the gear for wear as well. Any grooves in it will cause it to leak.
redwingvette is offline   Reply With Quote
Old 01-11-2004, 11:55 PM   #4
markdtn
CF Senior Member
markdtn's Avatar
Default Re: th400 speedometer cable leak (redwingvette)
THe gear can wear the "sleeve"that it goes through. Make sure the hole is not oblong and the gear fit is not loose.
markdtn is offline   Reply With Quote
Reload this Page th400 speedometer cable leak
Tags
400, cable, gear, housing, leak, leaking, leaks, seal, speed, speedo, speedometer, th400, tranny, transmission, turbo
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
