How much do you think this is worth?
Old 01-11-2004, 10:43 AM
DaddyO
DaddyO's Avatar
Default How much do you think this is worth?
What's do you think is the value of a 68 NOM BB conv that's in primer, taken apart, and pretty much in boxes? (that's all the info I know)
I have a friend in FL with a line on this car........so assume it's a FL car......
Old 01-12-2004, 12:08 AM
markdtn
markdtn's Avatar
Default Re: How much do you think this is worth? (DaddyO)
I'll take a lot of heat, but here goes. A roller body with no damage, non-modified front with no top and a good frame and birdcage is probably worth $3000-4000. This assumes it has a hood, wiper door, and correct headlights. The top assembly is worth at least $500 and a hardtop would be another $500. With a rebuildable engine and trans add another $500-1000 maybe. With the limited info you have provided I would say anywhere between $3500 and $8000. Heavy deductions for wrong or modified front end. $1000 deduction for bad frame. 68 has a lot of unique parts, some are almost impossible to find. If it's missing a lot of parts, it's probably best to pass.
Quick Reply: How much do you think this is worth?
