Why the ruckus over LT1's, LS1's, ect
7th Gear
In searching for an engine choice I've run across a lot of hype over these thin walled all alum 350's. One note that caught my eye was the fact that the max overbore is .010. Which makes them either non rebuildable or one freshing at most. I'm sure someone like Barton's could wet sleeve them, but that's a serious expense. Wouldn't an aftermarket all alum block be a better buy - at least it's rebuildable.
What am I missing?
Bob
What am I missing?
Bob
Re: Why the ruckus over LT1's, LS1's, ect (Bob Deeken)
Bob
Bob
Is that really true that the LS1 can't be re sleeved easily and can only be bored 10 thousands?
7th Gear
Re: Why the ruckus over LT1's, LS1's, ect (turtlevette)
You're right re the LT1 - ment to say LS6. But in the March 2004 issue of Corvette magazine they are doing a how-to on a LS1 and on page 90 it states that the LS1 block utilizes very thin steel liners and can't be bored more than .010 over stock. The photo beside verifies it.
That's the reason I asked - seemed like a throw away block to me. I come from the old school - back when if a 283 had been rebuilt twice. You bored it .120 over and slammed in used std bore 327 pistons. If the walls didn't rupture when you started it, they usually ran really good. Old 301.5 or 301 Chevy - or with larger mains from the factory a DZ 302 of early Camaro fame.
Bob
Bob
Bob
Bob
:cool:
I see Edelbrock is offering a carburated intake manifold too if you're really interested in these motors and want to keep the carb!...
[Modified by Signal, 6:22 PM 12/29/2003]
Cruise-In VII Veteran
St. Jude Donor '07
Re: Why the ruckus over LT1's, LS1's, ect (Signal)
Let me see, Because I can and its coooolll :cool: I'm doing it for top speed, good drag times, and I can cruise it to other states without worrying about ten miles to the gallon. This my second FI project, the first was fun, but never turned out like I wanted. Hopefully this will be different. :cheers:
1 Post
Prolly will be similar to what you see now, it is easier and sometimes cheaper for a person to buy a new crate eng than rebuild so you will prolly see a bunch of LS1/6 crate eng's in the near future that are close in price to a rebuild and will prolly be even more powerfull than the stock ones. And besides, todays eng will go over 100k no problem so if you rebuild it once it should last most people a lifetime, how many people will put 200k on an car?
Re: Why the ruckus over LT1's, LS1's, ect (Fevre)
IMO, the LS1 is the best production engine to date.
St. Jude Donor '07
Re: Why the ruckus over LT1's, LS1's, ect (LAvetteman)
The only problem I know of with LT1's is the recall for rod bearings and some minor issues with condensation in the opti spark. Other than that, they are great engines.
LS1 issues so far or some minor oil consumpion problems with different kinds of oil, but no major recalls.
7th Gear
Re: Why the ruckus over LT1's, LS1's, ect (bob)
What started all this is I'm searching for an engine to build, then I'll find a Vette to put it in. I originally thought of a 427 BBC, but am a little hesitant due to the weight over the front wheels as I want to try SoloII. Next, I considered a SB400 destroked to 377 using a 350 sized crank. The reason for this is I don't trust a cast crank for even mildly serious performance applications. However, since a SB 400 with iron block and heads is 80% or more of the 427 weight I wouldn't be gaining much.
I caught the weight of the LS1 and LS6 and that seems ideal. However, the Idea of being unable to rebuild a used engine even once has no appeal to a budget minded guy like me. I am now exploring the idea of using something like the powerplant out of a sprinter - maybe something along the lines of a Dart small M block which is all alum has replaceable sleeves I'm told.
However, I haven't given up on the LS1's - I'm going to contact someplace like Barton's that does sleeving. However, 20 years ago it used to cost almost $800 to sleeve old iron Hemi motors and get the job done right.
The reason I'm going after a alum intake, heads and block combo is that a C3 is no liteweight at 3600-3800 Lbs ready to run. If I can move 200-400 Lbs off the nose, the car will handle better and gain some snap as a 3200-3400 lb car at the same horsepower levels. Besides, have you ever driven or ridden in a large bore short stroke car like a 302 camero? Now, take that that combo and add another 70 cubic inchs and you'll see where I'm going.
Bob
Bob
I've read similar things about not being able to overbore the LS motors. I think that is old news.
Racing technology/experience has shown that these motors can be resleeved successfully. They sell all-bore stroker kits for the LS1s. Yeah, there are horror stories of sleeves dropping etc. But I think certain companies like Darton are proving that resleeving can be done successfully.
Check out some of the LS1 sites for more info. LS1tech.com is a good one. BTW, I haven't put a wrench on the motor yet on my 2002 Z28 and I am running 12s@107. Damn good engine!
Re: Why the ruckus over LT1's, LS1's, ect (nunus79)
There's an ongoing discussion right now on LS1tech regarding resleeving. It seems that MTI down in Texas is currently the best source for having it done. Some people have issues, others don't. Seems that MTI got a new machine and they're getting excellent results.
If all else fails, a new LS1 shortblock can be had for under $2k.
What started all this is I'm searching for an engine to build, then I'll find a Vette to put it in. I originally thought of a 427 BBC, but am a little hesitant due to the weight over the front wheels .
Bob
Bob
Dep
Re: Why the ruckus over LT1's, LS1's, ect (DJ Dep)
Bob
Bob: Don't let that weight thing scare you off. There are aluminum blocks made by a few companies besides Chevy that will give you a BBC in 427-454CI with the weight of a small block. Plus you have those dandy valves the size of beer cans :D
Dep
Bob
Dep
Re: Why the ruckus over LT1's, LS1's, ect (GrandSportC3)
Those aluminum big blocks are just a little bit on the expensive side...
Dep
