Bottle brush hone
Old 12-20-2003, 04:32 PM
Guru_4_hire
Guru_4_hire's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
Default Bottle brush hone
Is there anything special you need to know about using a bottle brush hone?
Old 12-20-2003, 08:38 PM
Guru_4_hire
Cruise-In V Veteran
Default Re: Bottle brush hone (Ed T)
Nobody has used a bottle brush hone?
Old 12-20-2003, 08:57 PM
JRD77VET
JRD77VET's Avatar
St. Jude '03-'04-'05-'06-'07-'08-'09-'10
Default Re: Bottle brush hone (Guru_4_hire)
I have, what are you honing?
:seeya Jeff
Old 12-20-2003, 09:00 PM
Pete79L82
Pete79L82's Avatar
For brake cylinders or lifter bores they are fine. Make sure you use a lot of lubricant. Would never use one on cylinder walls on any high performance application.
Old 12-20-2003, 09:13 PM
Guru_4_hire
Cruise-In V Veteran
Default Re: Bottle brush hone (Pete79L82)
I was thinking about honing down my cylinder bores for a quick and dirty rebuild. just want to clean things up to keep it going for a little bit. till I can build a new engine
Old 12-20-2003, 09:20 PM
JRD77VET
JRD77VET's Avatar
The bottle brush hone will work for breaking the glaze on the cylinder walls. However, if there is taper which you wish to remove you will need to use a conventional straight stone hone.
Make sure you use plenty of oil and don't dwell in one spot. The oil acts as a lubricant and also washes away the metal particles you've removed.
conventional honeWatch how far you bring the hone out of the bore. If you go past the center point of the stones you will taper the ends of the bore.
Do your homework and make sure everything matches that put into the motor. Too many times mismatched parts run like *poopie*
:seeya Jeff
Old 12-20-2003, 09:30 PM
Guru_4_hire
Cruise-In V Veteran
Default Re: Bottle brush hone (JRD77VET)
Interesting thanx
Old 12-20-2003, 09:34 PM
JRD77VET
JRD77VET's Avatar
Interesting thanx
:cheers: You're welcome
May you and your Mrs have a Merry Christmas
:seeya Jeff
Old 12-20-2003, 09:38 PM
Guru_4_hire
Cruise-In V Veteran
Thanx -- you too :cheers:
Old 12-21-2003, 12:17 AM
comp
comp's Avatar
use if your doing a cheappie job!!! be careful they cut quick :banghead:
and they leave a ton of grit. i've done a bunch of patch job's , if you know going
in it will only last X amount of time it's cool ,(i call them in cars overhauls)
it's pretty self explanitory :thumbs:
[Modified by comp, 8:53 AM 12/21/2003]
Old 12-21-2003, 02:43 AM
clem zahrobsky
clem zahrobsky's Avatar
Cruise-In I Veteran
Cruise-In II Veteran
just use scotch brite and wd-40 to deglaze the cylinder walls :chevy
Old 12-21-2003, 03:48 AM
comp
comp's Avatar
Default Re: Bottle brush hone (clem zahrobsky)
not enough cross hatch to seat in the cast( iron ) rings everytime, also more
work than 1-2 quick pass' with the b. brush
Old 12-21-2003, 04:20 AM
hermit
hermit's Avatar
I am no expert by any means but I would agree that they should only be used for breaking the glaze. That is not a place that you want to try to save a few dollars. It will probably end up costing you in the long run. Your best bet is to take the block to a machine shop and have it checked for taper and power honed or bored if necessary. The small amount it will cost you, even if you have to buy new pistons, will be money well spent.
Old 12-21-2003, 11:57 AM
71vettman
71vettman's Avatar
If the engine dosent absolutely have to be rebuilt right now id just run it how it is untill you have enough to get a bore job and new pistons. Either way its alot of work to tear your engine down and a ball hone just isnt worth it unless your cylinders are in almost new condition. If your cylinders are in that good of shape then there is no rush to rebuild it either.
If you do hone it out though select a brush that fits snug in the bore. Any thin type of oil would be good to use. Try to move the drill in and out at the right speed to get somwhere around a 30 degree cross hatch on the cylinder walls.
To Bottle brush hone
Quick Reply: Bottle brush hone
