Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-14-2003, 10:33 PM   #1
sqlguy
Junior Member
sqlguy's Avatar
Send a message via ICQ to sqlguy Send a message via AIM to sqlguy
Default Spark Plug Wiring Diagram For 350 Small Block
Ok, this might sound funny... But.. I just bought new spark plug cables today... and I am trying to put them on. I did not forget how they were on there before I removed them... BUT.. I think they were on wrong already. I had some exhaust work done (because I was LAZY) and had headers put on. I think they screwed something up.. LIKE THE WIRING ORDER. It has been runny VERY BADLY since then... No Power.. nothing... The spark plug wires were badly burned by the heat from the headers (idiots didn't route them very well when they plugged them back in).
Does anyone have a diagram of how it SHOULD be wired?
To which spark plug.. etc? I have a few manuals and I can't find a diagram anywhere! Driving me crazy. I really need something to go from. I know that I should already know this, but I am sad to say that I do not know the right order. AND I am not 100% sure that I know the cylinder numbering order...
1,3,5,7 Driver's side front to rear.
2,4,6,8 Passenger side, front to rear.
Is this right???
I still don't know the order on the Distributor. NO CLUE!!!
Any help will be appreciated.. I want to drive my baby tomorrow... :jester
Thanx All!!
-Mark
sqlguy is offline   Reply With Quote
Old 11-14-2003, 10:36 PM   #2
stpman
CF Senior Member
stpman's Avatar
Default Re: Spark Plug Wiring Diagram For 350 Small Block (sqlguy)
Yes
Drivers side 1, 3, 5, 7
Passenger side 2, 4, 6, 8
Firing order 1 8 4 3 6 5 7 2
Steve :steering:
stpman is offline   Reply With Quote
Old 11-14-2003, 10:41 PM   #3
Stevo81
CF Senior Member
Wouldn't he have to be sure of rotor direction (clockwise) and which distributor hole is #1 ... but a manual would have it...Haynes, Chiltons...not to mention the hundreds of other valuable items in these books...
Stevo81 is offline   Reply With Quote
Old 11-14-2003, 10:48 PM   #4
PatsLs1vette
CF Senior Member
PatsLs1vette's Avatar
Default Re: Spark Plug Wiring Diagram For 350 Small Block (Stevo81)
youll need to bring the number one cylinder piston up and determine where the rotor is pointing on the cap then go clockwise from there,and make sure its compression stroke .That would be number 1 then 8 4 3 6 5 7 2
PatsLs1vette is offline   Reply With Quote
Old 11-14-2003, 11:01 PM   #5
sqlguy
Junior Member
sqlguy's Avatar
Default Re: Spark Plug Wiring Diagram For 350 Small Block (patsnitrovette)
I appreciate your answer.. but I have no idea what you mean...
"bring the number one cylinder piston up" how in the world do I do that?
and.. "make sure its compression stroke" what does that mean?
THANK YOU!
-Mark
Old 11-14-2003, 11:13 PM   #6
homedawg247
Junior Member
Where cylinder #1 wire is located can vary depending on model and year. However, a common location is at about 11 o'clock (standing behind the engine). Try it like that and see if it runs any better.
homedawg247 is offline   Reply With Quote
Old 11-15-2003, 03:40 AM   #7
Brutus
CF Senior Member
Brutus's Avatar
Send a message via Yahoo to Brutus
Go to the top of this page and click on the tools heading, then look under tech tips. There you should find everything you need to know. Here's a start.
Click the image to open in full size.
[Modified by Brutus, 6:41 PM 11/15/2003]
Brutus is offline   Reply With Quote
Reload this Page Spark Plug Wiring Diagram For 350 Small Block
Tags
2001, 350, block, c3, corvette, diagram, distributor, electrical, number, order, plug, small, spark, wire, wiring
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
