Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-09-2003, 05:22 PM   #1
Blues77
CF Senior Member
Blues77's Avatar
Send a message via AIM to Blues77
Default tie rod end removal?
Looked at some past posts, and read a pickle fork could be used to knock out the tie rod end. Has anyone done this with the tie rod still attached to car? Seems like it would bend the dampner or put some major stress on it.
Also the rod that connects to the idler arm, has a slight bend before it attaches to idler. Normal?
Blues77 is offline   Reply With Quote
Old 10-09-2003, 05:33 PM   #2
Jeff78
CF Senior Member
Jeff78's Avatar
Default Re: tie rod end removal? (Blues77)
To seperate the tie rod end from the spindle remove the nut and use a 3 pound mall and hit the spindle where the tie rod slips into it.:smash: It is a taper fit and a few good whacks will loosen the fit and it will fall right out. Do not hit the tie rod threads though.
Jeff78 is offline   Reply With Quote
Old 10-09-2003, 05:57 PM   #3
Blues77
CF Senior Member
Blues77's Avatar
Default Re: tie rod end removal? (Jeff78)
Jeff, I gave it a few good wacks with the sledge but still no budge. I know I could eventually knock it out, but that dampner rod, looks like it could and will bend? I assume your dampner was still attached?
Old 10-09-2003, 05:58 PM   #4
Tom454
CF Senior Member
Tom454's Avatar
Pickle forks are okay as long as 1) the mount eye is not attached to anything with a bearing (such as the steering gear/pitman arm) because you can ruin the bearing etc, and 2) as long as you are not going to re-use the grease boot (the fork usually rips the boot).
I normally use a small pitman arm puller to remove tie rods... no muss. no fuss.
Last night, I removed the two outer tie rod ends from a Mustang GT with a small hammer just as described above (I'm replacing the rack & pinion) ... they weren't overly tight so they popped right out. Sometimes thay are really tight due to overtightening by a mechanic. In that case, the hammer and/or pickle fork will not work... a puller must be used.
Tom454 is offline   Reply With Quote
Old 10-09-2003, 06:37 PM   #5
stpman
CF Senior Member
stpman's Avatar
Default Re: tie rod end removal? (Tom454)
:iagree: I find in most cases the puller to be easier
Steve :steering:
stpman is offline   Reply With Quote
Old 10-09-2003, 07:01 PM   #6
vettfixr
CF Senior Member
vettfixr's Avatar
Default Re: tie rod end removal? (stpman)
I had to have a shoulder reconstructed because I thought the pickle fork was the way to go. I now have a set of pullers. Trust me, their much cheaper than surgery and less painfull. :yesnod:
vettfixr is offline   Reply With Quote
Old 10-10-2003, 11:35 PM   #7
catfishgeez
CF Member
catfishgeez's Avatar
a few years ago, I replaced the tie rod ends on my 68 using the the method that JEFF78 mentioned.
catfishgeez is offline   Reply With Quote
Old 10-11-2003, 12:01 AM   #8
RJR99SS
CF Senior Member
RJR99SS's Avatar
i just loosen the nut on the tie rod, but dont take it off.
While the nut is still on by 2 or 3 threads, hits it with a hammer until the taper breaks.
This way you wont damage the threads.
RJR99SS is offline   Reply With Quote
Old 10-11-2003, 12:43 AM   #9
Smokehouse69
CF Senior Member
Cruise-In VI Veteran
Cruise-In VII Veteran
Smokehouse69's Avatar
Default Re: tie rod end removal? (RJR99SS)
It helps alot to hold the side of the maul behind the eye and slam the other side with another hammer. It will distort the eye enough to slip off the taper, two or three whacks is usually all it takes.
Smokehouse69 is offline   Reply With Quote
Old 10-11-2003, 11:10 AM   #10
69vette66
CF Senior Member
69vette66's Avatar
Default Re: tie rod end removal? (Smokehouse69)
I use a pry bar and a hammer. Pry up or down(the other side of the nut) then whack the spindle with a hammer. Works everytime. Most of the time I have to reuse the parts and Not Damage the boots.
:cheers: Larry
69vette66 is offline   Reply With Quote
Old 04-02-2011, 04:14 PM   #11
LIJohn
Junior Member
Thanks Guys, Could not free the tie rod end on my '84 till I read the tip on using a puller. Two minutes later, it was free! Thanks!
John
LIJohn is offline   Reply With Quote
Old 04-02-2011, 05:08 PM   #12
Jack Wood
CF Senior Member
Jack Wood's Avatar
This tool from Summit Racing is the bomb: OTC-6297. I'd whacked and banged to the point of tears then a kind soul on this forum recommended it. It cost $49 but is worth it's weight in gold. Used it this morning.
Jack Wood is offline   Reply With Quote
Reload this Page tie rod end removal?
Tags
c3, cj7, corvette, end, fork, photos, puller, removal, remove, rod, rods, steering, tie, tips, vibration
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Front Coil Spring Removal Question 82Red C3 Tech/Performance 26 03-28-2011 09:13 PM
outer tie rod removal fcoppola C3 Tech/Performance 9 08-07-2005 08:34 PM
power steering control valve removal R. Bruno C3 Tech/Performance 49 02-21-2004 05:10 PM
The dreaded coil spring removal - tips? Pedro'74 C3 Tech/Performance 46 12-22-2002 11:41 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
