What cubic inch is a 454 bored .030 .040 and .060?
Old 10-06-2003, 09:27 PM
bhmyers
bhmyers's Avatar
Default What cubic inch is a 454 bored .030 .040 and .060?
What cubic inch is a 454 bored .030 .040 and .060? Is there a such thing as stroking a 454? When looking for a 454 block, is there a better year than others to look for, one that may have thicker walls? I want to build a big block for a project C3.
Old 10-06-2003, 09:57 PM
bhmyers
bhmyers's Avatar
Default Re: What cubic inch is a 454 bored .030 .040 and .060? (bhmyers)
someone must be able to help me......
Old 10-06-2003, 09:58 PM
Pete79L82
Pete79L82's Avatar
.030 over = 460
.040 over = 462
.060 over = 467
Yes you can stroke a 454 to over 500ci.
If you want a big bore, long stroke combo you would be better off with an aftermarket block. With aftermarket blocks you can get over 700ci.
[Modified by Pete79L82, 9:15 PM 10/6/2003]
Old 10-06-2003, 10:00 PM
467-Ratman
467-Ratman's Avatar
A 454 that is .060 over comes out to 466.9, 467ci. Most call it a 468 but I like the exact number, 467 just sounds cool, like its smaller cousin. Not sure about .030 over and .040 over, I think its like 460ci and 462?
Old 10-06-2003, 10:05 PM
Smokehouse69
Smokehouse69's Avatar
Cruise-In VI Veteran
Cruise-In VII Veteran
The deminsions of the bore and stroke of a stock 454 = 4.250" x 4.00"
If you bore it .030 you increase the bore to 4.280, now with a little 9th grade geometry, Ð Time the Radius squared times the height, times the number of cylinders.
Assuming a bore of 4.280 the radius would be 2.140 (, square that and multiply it by Ð (3.1416 is close enough for us) 4.5796 * 3.1416 * 4.00 = 57.59 cubic inches time 8= 460.39 cubic inches.
Now for .040 over = 462.55 cubic inches
Finally for .060 over = 466.87 cubic inches
Now for the different GM BB engines,
The biggest standard bore of a Mark IV and Mark V blocks is the 4.250, the Mark VI and Mark VII are completely different animals, I have no idea how close they are to "normal" big blocks.
Old 10-06-2003, 10:29 PM
GDaina
Support Corvetteforum!
GDaina's Avatar
Default Re: What cubic inch is a 454 bored .030 .040 and .060? (Smokehouse69)
Most desireable are the 4 bolt main blocks, but nothing wrong with the 2 bolt. BTW, 427, 454 blocks are identical, only difference is the stroke, and the 454 blocks are notched to accept the longer stroke. Rod lengthe between both are identical...they use the same rods.
To What cubic inch is a 454 bored .030 .040 and .060?
Quick Reply: What cubic inch is a 454 bored .030 .040 and .060?
