Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-24-2003, 12:16 AM   #1
carbster09
CF Senior Member
carbster09's Avatar
Default Hot feet in a Big Block......help
OK, this is maybe normal, but my big block is cooking my feet down here in texas. Is this normal? The damn thing puts out so much heat that I need AC and then it runs hot! :(
What did they do in 1971?
Any ideas? Maybe there's actually something wrong....I wonder? :confused:
Also any ideas on a door what squeaks driving down the road. I have oiled/greased and messed with it to no avail
Carbster09 :cuss
carbster09 is offline   Reply With Quote
Old 09-24-2003, 01:11 AM   #2
marky mark
CF Senior Member
marky mark's Avatar
Default Re: Hot feet in a Big Block......help (carbster09)
Sound like my car!!! Welcome to the wonderful world of big block 'Vettes!!!
Bad news .... it's perfectly normal.
Good news.... you can make improvements to help.
Heres some of what I did: (It helped that I had the engine & tranny out at the time):
Installed the thermal blankets under the driver and passenger compartments under the car (it attaches with a lot of clips).
Next the tunnel insulation piece. This goes above the tranny, a very big help I think
Then the foam collar that goes around the bellhousing (on the top and sides of the bellhousing). Keeps hot air from entering.
Then the reflective heat fabric that is thin enough to slide under the interior's front carpet. Do this all the way from were the carpet starts up near the firewall to the friont of the seats especially the tranny tunnel.
Then, remove the console and put some under there also. Try and cover as much as possible under there as heat will come up from the shifter, etc.
Another little thing that helps more with engine cooling is the front air dam.
Finally, look up under the dash and see if there are many openings to the firewall. Some of the rubber grommets that were put there to keep the air out might have fallen out. Kind of tough to work up in that area so I never got that done. It is kind of "porous" up in there!
All in all the results were very good! It still is warm but I can now drive it in my bare feet and not have any problem which is saying something.
Basically, if you don't do anything else do what you can to stop the hot air from entering through the tranny tunnel and install the stuff under the carpets, but buy the good stuff although it ain't cheap.
Oh make sure your heater isn't on!!!
Oh, my squeak sounds like it might be coming from either the door or the front cowling near where the doors and fenders meet. Haven't been able to locate it.
Good luck!
Regards, Mark :flag :chevy
[Modified by marky mark, 1:13 AM 9/24/2003]
marky mark is offline   Reply With Quote
Old 09-24-2003, 05:48 AM   #3
1979toy
CF Senior Member
1979toy's Avatar
Default Re: Hot feet in a Big Block......help (marky mark)
Mark that is the most complete listing of fixes for interior heat that I've ever seen. :cheers:
I'm doing a cut, paste and print to keep it on the garage wall to use as a checklist.
1979toy is offline   Reply With Quote
Old 09-24-2003, 07:44 AM   #4
vettfixr
CF Senior Member
vettfixr's Avatar
This topic's come up so many times i submitted a tech tip on it. Read the tech tip but briefly it's usually caused by the AC/Heater intake plenum pulling in hot air from the exhaust. The tech tip tells you how to fix it. Here's the link http://corvetteforum.com/techtips/vi...=241&TopicID=3
vettfixr is offline   Reply With Quote
Old 09-24-2003, 10:00 AM   #5
WeasleVette454
CF Senior Member
WeasleVette454's Avatar
Send a message via AIM to WeasleVette454
My '71 big block does the same thing to me. BOY does it get hot!! I too am going to cut and paste the to do list to help cut down on interior heat. I still think a set of the Hooker sides with a bit of JetHot action will help too!! :yesnod:
Weasle :D
WeasleVette454 is offline   Reply With Quote
Old 09-24-2003, 10:38 AM   #6
carbster09
CF Senior Member
carbster09's Avatar
Default Re: Hot feet in a Big Block......help (WeasleVette454)
Guys thanks for all of the advice. I see I have a little project on my hands! :cheers:
You know I was beginning to think I had a problem. :D
Carbster09
'71 Ont. Orange LS-5
Old 09-24-2003, 10:50 AM   #7
zwede
CF Senior Member
zwede's Avatar
Excellent checklist above! I have done all the steps except I'm missing the foam collar. Mine does not get hot at all. I think the coated headers help.
zwede is offline   Reply With Quote
Old 09-24-2003, 11:46 AM   #8
marky mark
CF Senior Member
marky mark's Avatar
Default Re: Hot feet in a Big Block......help (zwede)
I seem to have better luck with these kinds of things than I do with longevity of the big block motors themselves. The next one will be my third in three years, OUCH! Saving up for a crate motor I think, will be best for me.
Glad this was of some help.
For vendors I believe I used these: Eckler's , Dr. Rebuild and perhaps Zip.
On the engine cooling I forgot to mention the rubber strips that come in a kit for the radiator & it's frame. Also, the "half" sized under hood blanket helps some. A 160 therm really works as does an aluminum Edelbrock water pump. Some might go with a 180 therm as the 160 might actually be too cool if thats possible. And the fan clutch must be working properly.
Glad to have been of some assistance.
regards, Mark
Old 09-24-2003, 12:33 PM   #9
pzcg7l
CF Senior Member
pzcg7l's Avatar
:iagree:
They all transmit heat like that....Marky Mark's list is excellent - very thorough...
:steering:
pzcg7l is offline   Reply With Quote
Old 09-24-2003, 01:02 PM   #10
GATOR454
CF Senior Member
GATOR454's Avatar
Here is a link to a C5 insulation project. It was done primarily to reduce noise but I'm sure it will also help with heat. Plus it looks really nice before the carpet insall.
http://mikemercury.home.att.net/sound.htm
GATOR454 is offline   Reply With Quote
Old 09-24-2003, 01:19 PM   #11
Chuck Harmon
CF Senior Member
Chuck Harmon's Avatar
I have really become a rabid fan of Dynamat Xtreme. It is thin and very efficient in reducing both noise and heat. My concern with the thicker insulation over the trans tunnel is that it does reduce the air flow over the trans, which it needs, to cool it. This is not much of a concern for a daily driver that doesn't make much power on a regular basis, but for a car driven harder it is an issue. dynamat is very sticky and would be be put on the outside of the foot wells. They would also be protected by the tin splash shields. If the inside of the trans tunnel was really well cleaned and degreased, I think it would even sitck long term there.
I put dynamat on the complete inside of my passenger compartment, and am very satisfied. But I think it would be even better to have the aluminum surface shield be the first barrier to the heat instead of the last barrier.
Chuck
p.s. I should add that I also did the complete inside of my ZO6 which is my daily driver. It greatly reduced the road noise!
[Modified by Chuck Harmon, 10:22 AM 9/24/2003]
Chuck Harmon is offline   Reply With Quote
Old 09-24-2003, 07:20 PM   #12
jpatrick636
CF Senior Member
jpatrick636's Avatar
After I did most of the things mentioned in this post, which helped a great deal, it just so happened that it was time for a new radiator. I went with a Be Cool aluminium and Spal fans. I noticed a major change in cabin temperature as I could now run around 180 degrees. I also noticed a further reduction in cabin heat when I had a 3" exhaust installed.
jpatrick636 is offline   Reply With Quote
Old 09-24-2003, 07:24 PM   #13
77-C3 & 89-C4
CF Member
Best and easy thing to do is Remove the Heater Hoses. That will help some.
77-C3 & 89-C4 is offline   Reply With Quote
Reload this Page Hot feet in a Big Block......help
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 02:23 PM
440 Chrysler vs. Big Block Chevy: marky mark C3 Tech/Performance 205 01-13-2002 10:51 PM
my 383 experience mikey C4 Tech/Performance 11 09-05-2001 06:48 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
