STS baffle insertion
Old 09-27-2003, 01:31 PM
Older Than Dirt
Older Than Dirt's Avatar
Default STS baffle insertion
I just ordered a set of hooker headers-sidepipes from Jet-Hot. I will probably order a set of baffles from STS too. My question is do the baffles install before the sidepipes are slid over the header flange? Can they be installed and removed without taking the sidepipes off? Thanks for any info! :chevy
Old 09-27-2003, 02:20 PM
groovyjay
groovyjay's Avatar
Default Re: STS baffle insertion (Older Than Dirt)
Yes! :thumbs:
Old 09-27-2003, 06:41 PM
JCL
JCL's Avatar
OTD. YES to number one. And NO to number two..........JCL :yesnod: :yesnod:
Old 09-27-2003, 07:18 PM
GDaina
Support Corvetteforum!
GDaina's Avatar
Default Re: STS baffle insertion (JCL)
You're a good man Charlie Brown...most won't answer if a person buys from a competitor :cheers: :thumbs:
Old 09-27-2003, 08:18 PM
bertmeister
bertmeister's Avatar
Please post a picture when you get the sidepipes on. I also have an 81 and would be interested in seeing the sidepipes. :cheers:
Old 09-27-2003, 10:15 PM
Smokehouse69
Smokehouse69's Avatar
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: STS baffle insertion (GDaina)
I thought STS was JCL? :confused:
Old 09-27-2003, 10:17 PM
GDaina
GDaina's Avatar
Default Re: STS baffle insertion (Smokehouse69)
What is the complete name? I just call the inserts by JCL's. If the same, I'm bad...
Old 09-28-2003, 08:28 AM
JCL
JCL's Avatar
Chuck Harmon " named " them JCL's, from my forum handle. The company is STS............. JCL :yesnod: :yesnod:
Old 09-28-2003, 11:25 AM
74 vert
74 vert's Avatar
Location: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Here are some pictures I took while installing mine last year.
This shows the height of the car off of the garage floor
This picture shows how I alighned the baffles (different method, than the instructions provided with the baffles). I first located the front position to drill the hole for the attachment bolt so the bolt would slightly face the car from bottom dead center to "hide" it from view. I then attached the baffle to the pipe in front and eyed the back location until it was at the inflection point of the pipe and marked the drill spot. Drilled the second hole and then mounted the baffle on the inside and bolted everything together.
To slide the pipes onto the headers, I used a near 4 inch diameter polishing drill attachment to smooth out the inner diameter of the sidepipes, brushed on some copper anti-sieze onto the inside of the pipes and slid everything together before finally bolting everything to the car.
I spent a three day weekend on the project total from start to finish, taking several "thought" breaks along the way.
If I was to do it over, I would have sent the baffles to Jet-hot and had them Jet-Hot coated too.
[Modified by 74 vert, 10:31 AM 9/28/2003]
Old 09-28-2003, 01:55 PM
Older Than Dirt
Default Re: STS baffle insertion (74 vert)
Thanks for the replys and for the pics 74 vert. Do you really think I should have the baffles jet-hot coated also? Anyone run their baffles uncapped?
Old 09-28-2003, 07:44 PM
SmokedTires
SmokedTires's Avatar
Cruise-In III Veteran
St. Jude Donor '05
:yesnod: Not too bad when at idle, but crack the throttle and lookout !!! My new motor will idle around 1200-1400 rpms, so it'll be intereesting next spring ;)
Old 09-29-2003, 08:23 AM
Scooter70
Scooter70's Avatar
What material are the inserts? I'm going to order my inserts, drill the mounting holes, then send my sidepipes to Jet Hot (so that I don't have to drill thru the coating and create a spot for rust to start). Is it necessary (or at all beneficial) to have the baffles coated?
Old 09-29-2003, 09:30 AM
baja216
baja216's Avatar
Default Re: STS baffle insertion (bertmeister)
Here's a picture of my car with the sidepipes installed. I did not install them though, the previous owner put them on! :auto:
Old 09-29-2003, 08:18 PM
bertmeister
Default Re: STS baffle insertion (baja216)
:thumbs: :cheers:
Old 09-29-2003, 09:45 PM
Chuck Harmon
Chuck Harmon's Avatar
That would be correct, "initial"ly
:D
Chuck
To STS baffle insertion
Quick Reply: STS baffle insertion
