Stinky Exhaust
Old 09-16-2003, 01:28 PM
KSullender
KSullender's Avatar
Default Stinky Exhaust
I have a 71 convertible with stock 350 4spd. I find that after running the car my passenger and I smell like exhaust. I have had the engine tunned and the carb rebuilt.
My father in law thinks the mufflers are rotted inside from age. I know it doesn't have cats, but I have had alot of other muscle cars without cats and I don't smell like an exhaust pipe after driving it.
Any help??? :auto:
Old 09-16-2003, 01:40 PM
Stratos
Stratos's Avatar
Default Re: Stinky Exhaust (KSullender)
My guess, the exhaust pipes are leaking right under your shifter and your shifter boot under the leather outer cover is in bad shape.
Old 09-16-2003, 01:44 PM
Tom73
Tom73's Avatar
Welcome back to the world of no emission controls. Have the emission controls been removed?
Old 09-16-2003, 01:49 PM
marky mark
marky mark's Avatar
Sounds like it's running very rich and/or check for an exhaust leaks at the manifold to pipe connection on back until you are sure it's not leaking. Best method is to put it on a lift and have someone rev it up and down to listen for the noise that a leak will indicate (kind of a popping sound on de-celleration). Worked for me.
Regards, Mark
Old 09-16-2003, 02:07 PM
Robert N
Robert N's Avatar
Default Re: Stinky Exhaust (marky mark)
Had a similar problem. Car was too lean. Upped the jet size, smell went away. Had the car too rich at one opoint and the car smelled more like raw fuel when I shut her off.
If the mix is too lean, you tend to get more hydrocarbons released. That is the heavy exhaust smell that hangs in the air and on your clothes. If you smell like 'gas vapors', the mix is too rich.
[Modified by Robert N, 11:08 AM 9/16/2003]
[Modified by Robert N, 1:00 PM 9/16/2003]
Old 09-16-2003, 02:23 PM
KSullender
KSullender's Avatar
The exhaust is welded all the way back, and both shift boots have been replaced with new ones. Carb has been rebuilt and adjust by a carb shop.
Also, the car never came with emissions devices.
Old 09-16-2003, 02:27 PM
Robert N
Robert N's Avatar
The carb could still be jetted too lean.
Old 09-16-2003, 03:42 PM
KSullender
KSullender's Avatar
Default Re: Stinky Exhaust (Robert N)
Where can I get new jets? Do you know what size would be correct for this application? Wouldn't it be jetted too lean if it smelled like exhaust?
Old 09-16-2003, 04:03 PM
Robert N
Robert N's Avatar
Since you have (should if stock) a Rochester carb, I will be of no help. Since a shop recently tuned it, see if they can run the car to test for emissions (assuming that have a machine to do so). That should verify the problem. Then adjustment of the carb would be next.
Old 09-16-2003, 07:16 PM
rob75383
rob75383's Avatar
Do you get headaches??
Be VERY wary of carbon monoxide--the silent killer.
I had an '81 camaro in high school, and once had a bent tailpipe route exhaust into the trunk through a hole in the plastic bumper. Myself and three friends almost went to the emergency room after a 5 hour road trip!!!!
Man WHAT A HEADACHE I HAD from the CO poisoning!!!!
Get it taken care of!
To Stinky Exhaust
Quick Reply: Stinky Exhaust
