Trailing arm weight??
Old 09-16-2003, 10:09 AM
69Rat
69Rat's Avatar
Default Trailing arm weight??
Anybody know what a pair of bare trailing arms weigh? I"m looking to buy some used sets and need to factor in the shipping.
btw.. anyone wanting to sell their used ones.. drop me a line with the price you want.
Thanks!!
:cheers:
Old 09-16-2003, 10:13 AM
Twin_Turbo
Twin_Turbo's Avatar
Default Re: Trailing arm weight?? (69Rat)
They're not that heavy, I could weigh a pair if you want, don't know when I'll have time.
Old 09-16-2003, 10:16 AM
LemansBlue68
LemansBlue68's Avatar
If I remember correctly, mine were about 65 lbs each without the brake rotor. With the rotor they were about 80 lbs.
Old 09-16-2003, 10:36 AM
69Rat
69Rat's Avatar
Default Re: Trailing arm weight?? (LemansBlue68)
65lbs each? wow, that seems a bit heavy... but seeing as I haven't removed mine.. that could be. :confused:
I'm looking for about 6 sets if possible...
Old 09-16-2003, 10:44 AM
Twin_Turbo
Twin_Turbo's Avatar
do you mean the complete assembly or just the bare arm? The assembly indeed is heavy.
Old 09-16-2003, 11:02 AM
69Rat
69Rat's Avatar
Default Re: Trailing arm weight?? (Twin_Turbo)
No, just the bard arms.. bushings or not shouldn't make any significant difference. I just need the arms themselves. I'm going to be cutting them up a bit, then re-working them, and strengthing them a ton.
But I'm just looking for bare used arms.
Old 09-16-2003, 11:09 AM
Twin_Turbo
Twin_Turbo's Avatar
Thay are much lighter, maybe 10 to 15 lbs
Old 09-16-2003, 11:17 AM
69Rat
69Rat's Avatar
Ok.. that's on par with what I was thinking.... I figured 25 max each.
Thanks!
:cheers:
Old 09-16-2003, 03:30 PM
Van Steel
Premium Supporting Vendor
Van Steel's Avatar
Bare T-Arm 21 lbs - 10lbs each
T-Arm assembly w/out rotor - 42 lbs each
T-arm assembly w/rotor -57 lbs each
Old 09-16-2003, 03:34 PM
Twin_Turbo
Twin_Turbo's Avatar
Default Re: Trailing arm weight?? (Van Steel)
I was almost spot on LOL... good at guessing or what :D
Old 09-16-2003, 09:59 PM
69Rat
69Rat's Avatar
thanks for the facts Van! :hurray:
Good guessing TT!! :D
I didn't figure they were very heavy... now when I get done with them, they will be a tad more.. maybe 13-15lbs each.. but will support any power you want to toss at it! :thumbs:
Can we say BLOWN..... I knew you could... hehehe :reddevil
To Trailing arm weight??
Quick Reply: Trailing arm weight??
