Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-21-2003, 09:09 PM   #1
lvrpool32
CF Senior Member
lvrpool32's Avatar
Send a message via AIM to lvrpool32
Default Dual Point Distributor--How to set up??
Can anyone give me the basics on how to set up the points on a dual point distributor? I bought a dual point, tach drive mallory unit (used but in great condition) I had it in my car running, then I took it out to swop the intake (I very accuratley marked the position of the rotor arm and the direction of the tach drive cable) When out of the car I noticed that one set of points was disconnected..so I re-connected them, put the distributor back on the car.
Car starts up..everything is fine, until I go to check the timing.
I connect my timing light (positive, negative and clamp around number 1 plug lead) thing is...I can't see the timing mark on the balancer anymore.
Now I have remarked it and turned the distributor both ways (as much as it would travel) but I still cant see the mark. If it was outside of the limits of the travel I dont think it would run...what I am thinking is that somehow one of the set points is not set up right and making my timing light seem off...any ideas?
Someone got basic steps on how to tune a dual point distributor?
cheers
Nick
lvrpool32 is offline   Reply With Quote
Old 08-21-2003, 09:21 PM   #2
yellow 72
CF Senior Member
St. Jude Donor '09
yellow 72's Avatar
Default Re: Dual Point Distributor--How to set up?? (lvrpool32)
Reconnecting the other set of points probably altered the dwell and therefor the timing, but not as much as you describe....may be an obvious question but are you sure you have #1 wire?
yellow 72 is offline   Reply With Quote
Old 08-22-2003, 02:19 AM   #3
blackbirdpilot
CF Senior Member
If I remeber correctly ( I had a dual point Malory in my Camaro for a while). You will need to isolate the point sets. Insert a peice of thick cards stock or thin cardboard in one set. crank the motor and Adjust the points with a dwell meter utill they read 24-26degs. Then isolate the first set of points and set the second set. When you pull the cardboard and crank the motor reading should be 33-34 degs. If you use feller gagues, set each point set to.022 inch. Now you can reset the timming. Double check that you have the correct wire though. You should be able to see the mark regardless. If the timming was set so far off that you couldnt see it the motor would have a real hard time starting or back fire through the carb badly and kick back.
:thumbs:
blackbirdpilot is offline   Reply With Quote
Old 08-22-2003, 08:06 AM   #4
MYBLU71
CF Senior Member
MYBLU71's Avatar
Default Re: Dual Point Distributor--How to set up?? (blackbirdpilot)
:thumbs:
:iagree:
But, the best thing for you to do is buy the Unilite optical pickup conversion kit. Also, be sure you don't have the full 12 volts going to the distributor... It will burn up the points or conversion kit. If you are unsure, measure and ask about the ballast resistor that Mallory sells... I was having tons of problems with mine and then found out that there was no ballast resistor... burning my points up quickly!! :eek: I converted to the Unilite electronic unit and no more problems!!! :cool:
MYBLU71 is offline   Reply With Quote
Old 08-22-2003, 08:39 AM   #5
lvrpool32
CF Senior Member
lvrpool32's Avatar
Thanx for the info guys.
I think I may just be having an issue seeing the marker on the balancer (its a fluidamper type)
The car is running real nice, so the timing can't be that far off. I am amazed how quickly it winds up when I blip the throttle, I am guessing that when I went from the stock 8" to the smaller 6 something" that would help.
I am running a 274Xtreme comp cam, CC Roller rockers, DART heads, DART kool can intake, demon MS and it all seems to be doing good other than not being able to time the damn thing
:confused:
Once again...thanx guys.
Nick
Reload this Page Dual Point Distributor--How to set up??
Tags
back, corvette, daul, dist, distrbutors, distributor, dual, engine, install, kicks, point, points, resister, set, setup, tach, tuning
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 89 09-24-2013 01:59 PM
Performance differance between #653 dual quad intake and aftermarket dual quad intake wesmigletz C1 & C2 Corvettes 14 12-05-2004 01:45 AM
Timing 1quik6 C1 & C2 Corvettes 18 06-18-2004 11:23 PM
Correct dwell for 383 strocker de_cat55 C3 Tech/Performance 11 07-09-2003 09:21 PM
Help me choose new heads your drinking buddy Engine Mods 11 09-15-2001 02:14 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
