Check out the underside of this Vette
Old 08-08-2003, 07:50 PM
kaz1961
kaz1961's Avatar
Default Check out the underside of this Vette
I am looking to buy my first Vette and would appreciate it if you guys could look at these pictures http://f1.pg.photos.yahoo.com/ssekaz photos I have no interest in this car but want to know how bad this rust is. Would this be a car to avoid at all costs? Thanks for the advice.
Old 08-08-2003, 09:11 PM
79VetteMike
79VetteMike's Avatar
Default Re: Check out the underside of this Vette (kaz1961)
kinda hard to tell from those 2 photos. It doesn't look too bad-mostly surface rust. Look around the bird cage and the rear of the frame- that seems to be where most of the rust damage occurs.
Old 08-08-2003, 09:41 PM
Jvette73
Jvette73's Avatar
Maybe its just me but that first pic looks doctered. Certain portions of it look blurred while other portions are still in focus...strange
Old 08-08-2003, 10:22 PM
MotorHead
MotorHead's Avatar
Location: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: Check out the underside of this Vette (Jvette73)
I agree that picture looks funny, almost like trying to cover up a patch job :confused:
Old 08-09-2003, 09:41 AM
Big Fish
Support Corvetteforum!
Big Fish's Avatar
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Any car that's driven will probably look like this, but these are not the areas to be concerned with. Bird cage and rear corners above the gussets are the biggest culprits.
Old 08-09-2003, 11:52 AM
ken markusa
ken markusa's Avatar
The picture looks out of focus in parts because the picture was probably shot with the lens wide open because of not much available light so you end up with a shallow detph of field which are the parts of the picture that are in focus this is much more acute in close up shoots.
:cheers:
Ken with your photography lesson of the day
Old 08-09-2003, 03:02 PM
Steve Grodin
Steve Grodin's Avatar
In the first picture you can see someone installed the end link bolts upside down. :chevy
Old 08-09-2003, 03:06 PM
FASGLAS
FASGLAS's Avatar
CI 4-5-6-7-8-9-10-11 Vet
St. Jude Donor '06-'07-'08-'09
I noticed that too. Hmmmmm.
Old 08-09-2003, 03:22 PM
phrogs
phrogs's Avatar
Default Re: Check out the underside of this Vette (FASGLAS)
Well from those pictures that is not the rust you need to worry about
that is just surface rust and will need to be delt with but not its not a issue.
like the others have said you need to look at the birdcage that is the worst, also look into the windshield and see if you can see any rustt build up guarentee you will need to do some work on it if you see any.
heres a picture of my frame its just surface rust it is all solid!
Old 08-09-2003, 11:53 PM
ddecart
ddecart's Avatar
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Thise pics don't look too bad.
But they're not where you need to look for rust. The main location where C3s rust is along the frame rail, under the door, right in front of the rear wheel. This area seems to take all the abuse rust-wise.
Also, looking along the windshield pillars is a good idea, too. Gives oyu some idea of the condition of the birdcage, although not always accurate.
Old 08-10-2003, 01:03 AM
phrogs
phrogs's Avatar
Default Re: Check out the underside of this Vette (ddecart)
Here are some pics of my bird cage.
mine is not even bad. just needs a little help :yesnod:
my car sat in the weather for many years.
johnny
To Check out the underside of this Vette
Quick Reply: Check out the underside of this Vette
