700R4 & 3.73s: too MUCH gear ratio???
Re: 700R4 & 3.73s: too MUCH gear ratio??? (Glensgages)
But, I'm not gonna 'cut-it-up' (swap motor and/or transmission) in any way.....
:cheers:
Re: 700R4 & 3.73s: too MUCH gear ratio??? (UKPaul)
Couldn't you swap the cam, raise compression, dual pipes, etc to get a bit more out of the motor?
Hi Glen,
I had a 700-R4 with 3.73 gears in my 406 SBC. I felt it was an ideal combination and would not have gone higher or lower with the ratio given it was a street driver. Since then I have gone to a stroker and T56 and the 3.73 seem a little too much.
Good Luck,
Ken,
Albuquerque
Good Luck,
Ken,
Albuquerque
1 Post
Re: 700R4 & 3.73s: too MUCH gear ratio??? (CORKVETTE1)
i said it before and i will say it again a lot of gear is just a crutch for lack of horsepower look at my 3:07 rear gear 700r4 does 1.50 60 ft and it will be in the 1.4s soon as we have better air in the fall :cheers:
Think you mean torque, that is what launches you. Bet you would get better times with a higher gear but loose some mph. Impressive times non the less.
Re: 700R4 & 3.73s: too MUCH gear ratio??? (ENCHANTMENT)
I had a 700-R4 with 3.73 gears in my 406 SBC.....
I know some members here have put 700R4s in their C3s. The 1st gear ratio in 700R4s is 3.06:1. My '82 Cross-Fire (no-laughing, pleeze!) has the 700R4, and 2.87:1 rear gears. The Cross-Fire needs ALL the help it can get, so, I'm considering swapping the 2.87s for 3.73s. My question is this: the 'effective' gear ratio in 1st will be 11.4:1 (3.06 x 3.73), deeper than my Z28 with custom gears in the THM400 (2.75:1) and 4.10 cogs (11.27:1). I'll eventually up-grade the Cross-Fire to 300-325 HP (where's CARTEK when you need 'em? ), and run BFG Drag Radials, but, WILL THIS THING HOOK-UP? Is it 'too-much' 1st gear? Other offereings are 3.31:1 and 3.55:1 ratios. Anybody with the 700R4 and 'gears', please respond. THANKS in advance.....
