Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-06-2003, 08:31 PM   #1
sammyb
CF Senior Member
sammyb's Avatar
Default How to remove windshield scratches caused by wiper?
My '69 has a nasty scratch on the windshield from where the stupid previous owner ran the wipers without a blade installed.
How can I get this scratch out of the windshield? Any tips, tricks, products??
Thanks,
Sam
sammyb is offline   Reply With Quote
Old 08-06-2003, 08:37 PM   #2
Corey_68
CF Senior Member
Corey_68's Avatar
Default Re: How to remove windshield scratches caused by wiper? (sammyb)
I believe Eastwood sells a glass polishing kit. It's a very fine abrasive and I was told by a fellow hot rodder it works quite well.
:cheers:
Corey_68 is offline   Reply With Quote
Old 08-06-2003, 08:56 PM   #3
gdh
CF Senior Member
Bon Ami or cerium oxide (what a lot of detailers use).
gdh is offline   Reply With Quote
Old 08-06-2003, 09:10 PM   #4
yellow 72
CF Senior Member
St. Jude Donor '09
yellow 72's Avatar
If the scratch is deep enough to catch your fingernail forget it, it can't be removed :nonod:
Mike :cheers:
yellow 72 is offline   Reply With Quote
Old 08-06-2003, 10:13 PM   #5
Corvette ED
CF Senior Member
Corvette ED's Avatar
Location: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Default Re: How to remove windshield scratches caused by wiper? (yellow 72)
My 75 convertible had a wiper mark across the right side and the left arm was bent at one time and was rubbing the lower part of the windshield. I had the windshield replaced last week. Now the car looks good and my vision is clear. It only cost me $230.00 installed. When the glass installers were removing the old one they showed me that time had taken its toll and the windshield wasn't even sticking to the tape at the top anymore.
My windshield frame was in good shape with no rust through and my new glass is in and sealed. No more windshield leaks.
Corvette ED is offline   Reply With Quote
Old 08-06-2003, 10:22 PM   #6
GrandSportC3
CF Senior Member
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03 & '06
GrandSportC3's Avatar
Send a message via AIM to GrandSportC3 Send a message via Yahoo to GrandSportC3 Send a message via Skype™ to GrandSportC3
C3 windshields aren't that expensive... They are around $200 installed...
GrandSportC3 is offline   Reply With Quote
Old 08-07-2003, 11:59 AM   #7
vettfixr
CF Senior Member
vettfixr's Avatar
Fforget trying to remove it with the Eastwood kit. It doesn't work. I tried to buff a spot about 6 inches square one weekend. After a few hours it didn't even make a dent in the haze. I wouldn't even attempt it on a good sized scratch. Just get a new windshield and be done with it.
vettfixr is offline   Reply With Quote
Old 08-07-2003, 12:12 PM   #8
75 BBC Stingray
CF Senior Member
75 BBC Stingray's Avatar
If you are really set on getting the scratch removed from the windshield instead of replacing it, I would recommend that you find a shop that has the 3M glass repair system. I've seen the abrasive take out some pretty tough scratches. Unfortunately, the tool to use the pads is quite expensive, putting it out of reach of most home repair budgets.
http://multimedia.mmm.com/mws/mediaw...___52yk7yun92-
http://multimedia.mmm.com/mws/mediaw...yyyfD63TXs4ZE-
http://multimedia.mmm.com/mws/mediaw...uuuB&ee5soh70-
75 BBC Stingray is offline   Reply With Quote
Old 08-07-2003, 04:10 PM   #9
TexasShark
CF Member
TexasShark's Avatar
How deep the scratch is is definatley a determining factor. However, if it isn't bad save money on a bunch of products that may or may not work and go get yourself a bundle of newspaper and toothpaste. The toothpaste is a mild abrasive and the newsprint (b&w only) won't streak the windows. BTW-if you are a smoker, save your ashes (no butts). They're great for polishing (works as jewelry cleaner, too). OK, done with my Martha Stewart moment, need football :leaving:
TexasShark is offline   Reply With Quote
Old 08-07-2003, 04:17 PM   #10
Scooter70
CF Senior Member
Scooter70's Avatar
Send a message via AIM to Scooter70
Default Re: How to remove windshield scratches caused by wiper? (TexasShark)
I tried the Eastwood stuff on my side windows. It didn't work all that well. I'll end up buying all new glass eventually.
Scooter70 is offline   Reply With Quote
Old 08-07-2003, 04:19 PM   #11
LAvetteman
CF Senior Member
St. Jude Contributor
Mike :cheers:
:iagree: If that scratch is anything like what I have seen once before where a blade fell off and the wiper arm"GOUGED" the glass, forget about it the glass has actually been dug into. As others have mentioned, if it catches your finger nail it can't be repaired.
I replaced the windshield on my 71 two years ago. $160.00 glass and labor.
LAvetteman is offline   Reply With Quote
Reload this Page How to remove windshield scratches caused by wiper?
Tags
arm, buff, caused, forum, marks, remove, removed, removewiper, removing, scratch, scratches, sratches, windshield, wiper, wipers
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
