Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-04-2003, 08:50 AM   #1
MELVIN
CF Senior Member
Default Full synthetic engine oil comparison: Mobil 1 vs Castrol
Im considering switching from Mobil 1 to the Castrol full synthetic Ive been seeing lately. Does anyone have any historical/peformance data on the Castrol Full synthetic as comparted to Mobil 1?
MELVIN is offline   Reply With Quote
Old 08-04-2003, 09:05 AM   #2
Neo Fender
CF Senior Member
Default Re: Full synthetic engine oil comparison: Mobil 1 vs Castrol (MELVIN)
Mobil 1 tried to sue Castrol claiming that Syntec does not use a true synthetic basestock. I think there may be some merit to Mobil 1's case. Even prior to hearing this I was a diehard Castrol dino oil user. On my new vehicle however, I use Mobil 1 or Royal Purple.
I think a lot of the "best oil" debates are just hype but it makes for some interesting reading....sometimes.
From http://www.micapeak.com/bike/ST1300/Oils1.html
"In the late 1990s, Castrol started selling an oil made from Group III base oil and called it SynTec Full Synthetic. Mobil sued Castrol, asserting that this oil was not synthetic, but simply a highly refined petroleum oil, and therefore it was false advertising to call it synthetic. In 1999, Mobil lost their lawsuit. It was decided that the word "synthetic" was a marketing term and referred to properties, not to production methods or ingredients. Castrol continues to make SynTec out of Group III base oils, that is highly purified oil with most all of the cockroach bits removed.
Shortly after Mobil lost their lawsuit, most oil companies started reformulating their synthetic oils to use Group III base stocks instead of PAOs or diester stocks as their primary component. Most of the "synthetic oil" you can buy today is actually mostly made of this highly-distilled and purified dino-juice called Group III oil. Group III base oils cost about half as much as the synthetics. By using a blend of mostly Group III oils and a smaller amount of "true" synthetics, the oil companies can produce a product that has nearly the same properties as the "true" synthetics, and nearly the same cost as the Group III oil. In fact, Mobil-1 is now primarily made from Group III unconventional base oils, exactly the stuff Mobil was claiming was not really synthetic. The much more expensive traditional synthetics are now available in their pure forms only in more expensive and harder to obtain oils."
[Modified by Neo Fender, 8:42 AM 8/4/2003]
Neo Fender is offline   Reply With Quote
Old 08-04-2003, 10:24 AM   #3
tersian
CF Senior Member
tersian's Avatar
Default Re: Full synthetic engine oil comparison: Mobil 1 vs Castrol (Neo Fender)
Neo,
Thanks for the info, really interesting stuff. To me anyway, but I'm a systems geek(read: engineer) so this stuff is a good read for me.
tersian is offline   Reply With Quote
Old 08-04-2003, 10:30 AM   #4
JB
CF Senior Member
St. Jude Contributor
JB's Avatar
Default Re: Full synthetic engine oil comparison: Mobil 1 vs Castrol (tersian)
That's just depressing. What kind of brutalizing of the English language is involved in some judge deciding that "synthetic" actually means "dino oil that's almost as good as real synthetic."
So are there any easily available commercial products that are actually honest-to-God 100% man-made synthetic?
JB
JB is offline   Reply With Quote
Old 08-04-2003, 10:34 AM   #5
mountainmotor
CF Senior Member
mountainmotor's Avatar
Quote:
"In fact, Mobil-1 is now primarily made from Group III unconventional base oils, exactly the stuff Mobil was claiming was not really synthetic."
That statement is absolutley not true . The Mobil Supersyn is comprised of various viscosity PAO's with a fantastic additive package. It is the best Mobil oil ever offered for a Passenger car and is more VI stable compared to the Syntec analysis's I have seen .
The only Mobil oil that uses group III basestocks is called System-S and is a 5/40wt offered in Europe only. The new 5/20 they have might be a group III basestock but you will not see Mobil call it a Synthetic anytime soon.
Group III fake synthetics are not all that bad , in the new 5/40's PCMO's anyway . These generally use a small amount of PAO in them along with a tweeked additive package that merits a look at, seeing these oils are generally 2.90 - 3.50 per quart and meet the VW 505 , Mercedes Benz 229.3 and BMW service fill along with these specs comes a High Temp/High Shear of over 4.2. For a 4-6k drain interval I ,IMO , would put the following oils up against any of the mail order oils in terms of protection and cost vs performance if the motor is of the type that could actually use a low to mid VI 40wt.
Kendall GT-1 5/40
76 Full Syn 5/40
Castrol 5/40 - not to be confused with Syntec
Chevron 5/40
Valvoline 5/40
For warmer climates or the hotter cammed OHV V-8's the new Diesel 5/40's with the API service SL " gasoline engine " just might be the ticket for some.
These include the
Rotella T 5/40 with it's Slack Wax Base Oil
Valvoline Premium Blue Extreme 5/40 - group II,PAO
Petro Canada 5/40 Group III
Citgo Syndurance ----it's a PAO,group III,II blend
There is more but that's what came to immediate mind as good to great new contenders on the block.
mountainmotor is offline   Reply With Quote
Old 08-04-2003, 10:35 AM   #6
Corey_68
CF Senior Member
Corey_68's Avatar
Default Re: Full synthetic engine oil comparison: Mobil 1 vs Castrol (mountainmotor)
Mobil 1 for me. :yesnod:
Corey_68 is offline   Reply With Quote
Old 08-04-2003, 10:49 AM   #7
Smokehouse69
CF Senior Member
Cruise-In VI Veteran
Cruise-In VII Veteran
Smokehouse69's Avatar
According to the Amsoil website, their synthetic is made from 100% PAO base stock and additives, no Dino oil in the base stock.
Smokehouse69 is offline   Reply With Quote
Old 08-04-2003, 11:03 AM   #8
mountainmotor
CF Senior Member
Default Re: Full synthetic engine oil comparison: Mobil 1 vs Castrol (Smokehouse69)
Yeah but go back to their site and see the 7500 series oils they tout as " Synthetic " . That oil is only a group III basestock .
They advertise true PAO's and then do an about face...they can't have it both ways :p: Or can they ? Guess so if the consumer is not educated on their way of advertising.
Marketing Hype gives some oils bad names
:sleep:
Old 08-04-2003, 11:08 AM   #9
gdh
CF Senior Member
Curtis just tried to call you.
gdh is offline   Reply With Quote
Old 08-04-2003, 11:53 AM   #10
WydGlydJim
CF Senior Member
WydGlydJim's Avatar
:sleep:
I've had good luck with Amsoil.....over 100k on both my daily drivers, with no engine issues, and I only change the oil once a year on both since new. '93 Chevy P/U, and '98 Ford Expedition
WydGlydJim is online now   Reply With Quote
Old 08-04-2003, 01:56 PM   #11
Tominator
CF Senior Member
Tominator's Avatar
This info is based on rider mower experince; broke it in with Quaker State dino and switched to Mobil 1 and it ran great. Keep in mine I mow and use it for snow removal too.
Last summer switched to Castrol full synthetic and in the summer heat my engine started knocking so switched back to Mobil 1 and the problem went away.
I will never use Castrol full synthetic in anything again, the mower is much different than a car for one it's air cooled.
Tominator is offline   Reply With Quote
Old 08-04-2003, 01:56 PM   #12
LAvetteman
CF Senior Member
Default Re: Full synthetic engine oil comparison: Mobil 1 vs Castrol (WydGlydJim)
:sleep:
Sure, some people swear by $.99 walmart oil, never any problems. I dont, but my point is as I am sure others, if you are paying high dollar for Synthetic oil, you want what you are paying for....
LAvetteman is offline   Reply With Quote
Old 08-04-2003, 02:13 PM   #13
Twin_Turbo
CF Senior Member
Default Re: Full synthetic engine oil comparison: Mobil 1 vs Castrol (LAvetteman)
I get Shell Ultra Helix competition 10W60 (Ferrari Challenge) for free so why run anything else :D
Twin_Turbo is offline   Reply With Quote
Old 08-04-2003, 06:50 PM   #14
WydGlydJim
CF Senior Member
WydGlydJim's Avatar
Not to appear argumentative, :D But......The Amsoil I use is 100% synthetic, and Amsoil was "first in synthetics", and around long before any of this litigation over blends, which is really what we are talking about. I don't think any of these other oils claim to be 100% synthetic, and if they do, it is false advertising. As far as being high priced, I just don't look at it that way. If I use an oil that is three times as expensive. but offers 5 times the life over conventional oils, where is the added cost. There is none. As far as getting what I pay for, I do. I get a quality motor oil, that is comparable in cost to other oils, and the advantage of much greater service intervals which saves me time, ( which is really the most important to me ) and it is better for the planet. Any way you look at it with an open mind, Amsoil is the smart choice. Damn, they should pay me for this advertising!
:cheers:
Click the image to open in full size.
Old 08-04-2003, 07:11 PM   #15
Larry B.
CF Senior Member
Larry B.'s Avatar
Here's my experience. The ONLY oil related problem I have ever had was with a 92 Corvette that had ALWAYS been serviced from day one at a chevy dealer with Mobil I before I got it from the 1st owner. I continued using Mobil I . A 90 k a lifter gaulled.. Stuck up causing a very difficult to find miss. But the engine was clean... Tide would have done that.. :lol: :lol: I have 184K on my 3.1 Lumina APV.... Valvoline... NEVER touched the inside on the engine. Doesn't smoke,or use oil and still runs perfect. No synthetics in my cars....
Larry B. is offline   Reply With Quote
Old 08-06-2003, 10:19 AM   #16
wingnut
Junior Member
Default Re: Full synthetic engine oil comparison: Mobil 1 vs Castrol (bluevetteman)
Motorcyclist Magazine had a good oil comparison article a month or 2 ago. It mentioned a lot of the points in this thread and convinced me to switch from Castrol to Mobil 1. The article was obviously bike-focused but most of it applied to oil in general.
wingnut is offline   Reply With Quote
Old 08-06-2003, 10:38 AM   #17
Dwayne 76
CF Senior Member
Dwayne 76's Avatar
Send a message via ICQ to Dwayne 76 Send a message via AIM to Dwayne 76 Send a message via MSN to Dwayne 76
Default Re: Full synthetic engine oil comparison: Mobil 1 vs Castrol (wingnut)
I just switched to Mobil 1 after reading this article. Hey maybe its all BS, but perception is everything.
Dwayne 76 is offline   Reply With Quote
Old 08-06-2003, 10:58 AM   #18
LemansBlue68
CF Senior Member
LemansBlue68's Avatar
Location: Those who say it can't be done should get out of the way of the ones who are doing it.
Use a decent SG or better rated "dino" oil and change it every 3000 miles. You'll do just as well as any synthetics and pay 1/4 of the cost. If you want to run synthetics, you should still change your oil every 3000. So if you want to pour that extra $3/qt down the drain all the power to ya if it makes ya feel better. The biggest factor that I've seen with respect to wear and carbon accumulation in the 100K+ fleet motors that I've looked at (and we run 'em all over the country) is the regularity of the oil changes--synthetic oil or not.
When Mobil 1 first came out, they touted that you could extend your oil changes out to 25,000 miles. They back peddled on that statement really fast when customers started taking them literally.
LemansBlue68 is offline   Reply With Quote
Old 08-06-2003, 11:04 AM   #19
Dwayne 76
CF Senior Member
Dwayne 76's Avatar
Default Re: Full synthetic engine oil comparison: Mobil 1 vs Castrol (LemansBlue68)
Actually I read a report many moons ago about A german car company that did a test using two different oils, Dino and Synthetic. THey put something like 100,000KM's on the cars, doing oil changes every 5000 Km's. The car with Dino oil had the engine wear of car that had a 100,000KM's, no surprise there. The car with Synthetic had athe same engine wear as a car with about 10,000 KM's of wear. So, if I could find the article I'd post it, but I can't but I did read it. So, for me Synthetic is the only way to go.
Old 08-06-2003, 11:38 AM   #20
BeaterShark
CF Senior Member
What do you base this opinion on?
Here is a guy that is running M1 and sending a sample in for analysis every 1k miles: http://neptune.spacebears.com/cars/s.../oil-life.html
You will notice that the rate of the wear items (mainly Iron and Lead) did not really increase untill the oil was getting 10k+ miles on it. In fact the 6000 mil to 9000 mile interval had just about the exact same wear as the 0 - 3000 mile interval.
BeaterShark is offline   Reply With Quote
Reload this Page Full synthetic engine oil comparison: Mobil 1 vs Castrol
Tags
01, 505, blue, castrol, comparison, engine, extreme, full, ineo, mobil, oil, premium, synthetic, valvoline, vw
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
