Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-29-2003, 02:55 AM   #1
nwmaximus
Junior Member
nwmaximus's Avatar
Send a message via AIM to nwmaximus
Default Any recommendations on changing from side to top post battery connections?
Or do you think it makes any differance at all.I know top is easier to work with. :D :sleep:
nwmaximus is offline   Reply With Quote
Old 07-29-2003, 03:07 AM   #2
standup
CF Senior Member
standup's Avatar
Default Re: Any recommendations on changing from side to top post battery connections? (nwmaximus)
side posts????????........I'm an idiot willing to learn here.......all I've ever known about batteries is that the posts are on the top........but one cool thing I've found on my Vette is that I've got wing-nuts fixing the cables down.....that makes it much easier to work with............
standup is offline   Reply With Quote
Old 07-29-2003, 04:53 AM   #3
Sting Raycin
CF Senior Member
Sting Raycin's Avatar
You want to change from side-mount to top-post? I have always found the side-mount to be more trouble free than the top post. As long as the proper wrench is used the side mount terminals will last. I have never had a side-mount cause corrosion. I have heard of issues with AC delco batteries leaking out of the side post, but I have never had that problem.
Sting Raycin is offline   Reply With Quote
Old 07-29-2003, 06:31 AM   #4
Larry B.
CF Senior Member
Larry B.'s Avatar
Default Re: Any recommendations on changing from side to top post battery connections? (Sting Raycin)
There was class action suite about the Delcos leaking. My old 92 did that... Really made a big mess. There were several years in the late 90's that were leak prone.
I have an Auto-zone battery that has both top and side posts pust a THREE year FREE replacement.
Larry B. is offline   Reply With Quote
Old 07-29-2003, 07:11 AM   #5
OkeeGuy
CF Senior Member
OkeeGuy's Avatar
Default Re: Any recommendations on changing from side to top post battery connections? (bluevetteman)
i have a top post and have replaced the cable ends...
i have never been a fan of side posts personaly...
too fragile, the really suck when trying to jump start in the event that you have to do so...and in the case of our vette's battery location, top posts are much easier to get at...
OkeeGuy is offline   Reply With Quote
Old 07-29-2003, 08:11 AM   #6
desi
CF Senior Member
desi's Avatar
Do it. Switch to top. Side ones don't work very well, and I had one leak on me. Instead of just bolting the terminal on, get a quick disconnect. Works great. I bought mine for only $5 canadian. Now I have one in each friends/relatives car. :yesnod:
desi is offline   Reply With Quote
Old 07-29-2003, 08:48 AM   #7
Ganey
CF Senior Member
Ganey's Avatar
Quote:
You want to change from side-mount to top-post? I have always found the side-mount to be more trouble free than the top post. As long as the proper wrench is used the side mount terminals will last. ...
The side works great in our cars.
It is possible to overtighten & pull out the thread connector. Carry a top/side adapter in both hot rods. Side/top in both hot rods & use side. Changed to 9/16 bolts.
:cool:
Ganey is offline   Reply With Quote
Reload this Page Any recommendations on changing from side to top post battery connections?
Tags
batt, battery, cables, car, change, changing, connection, how, mount, post, posts, replace, side, switch, top
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
