I finally did it!
Old 07-27-2003, 01:33 PM
shotgun_000
shotgun_000's Avatar
Default I finally did it!
I broke the 5 second barrier! :party: :party:
Yeah, those of you with the AR 383's are probably going :rolleyes: :lol:
Next goal, and more expensive, break the 4 second barrier. :cheers:
One question - If I am able to run 0-60mph in less than 5 seconds, how come I don't have the slightest hint of wheel spin? Seems like with roughly 300hp the tires would at least chirp the P255's, but then again I'm not complaining. Traction could help me beat faster cars off the line :thumbs:
Old 07-27-2003, 01:44 PM
shotgun_000
Default Re: I finally did it! (shotgun_000)
One more question.
The last time I run G-Tech, my best was 5.1 seconds, and I did several runs.
I have made no modifications to the engine since that time, about a month ago.
The engine has about 8,000 miles on it so I expect it to be fully broke in. The weather today was worse than during the last run I made: Mid 80's, with very high humidity.
The only thing that is different than past runs is the grade of gasoline I'm using. I used to use 93, since I was unsure of the exact compression ratio. Since I had no pinging, I decided to try 87 Octane two weeks ago. Everything is still good, no pinging with 87.
As weird as this sounds, could the extra power come from using a grade of gasoline more suitable to my compression ratio?
Old 07-27-2003, 05:10 PM
QuickVet
QuickVet's Avatar
I can break the 4 second barrier :D Dont know how accurate it is but i do recall do that.
Old 07-27-2003, 05:12 PM
Corey_68
Corey_68's Avatar
Default Re: I finally did it! (QuickVet)
If you have ANY wheel spin it throws off the time to some extent. :yesnod:
Old 07-27-2003, 05:48 PM
shotgun_000
You suck! :p: :jester
If I ever hit the lottery, maybe I can afford to break it :lol:
Old 07-27-2003, 06:06 PM
SCVetteGuy
SCVetteGuy's Avatar
Nice job Shotgun!!! :thumbs: We need someone in Spartanburg with a fast C3, b/c mine definitely isn't!!!!
Shotgun, I was wondering where you do your tests at. I'm trying to find a good place to test mine with the G-tech.
[Modified by SCVetteGuy, 5:12 PM 7/27/2003]
Old 07-27-2003, 06:29 PM
QuickVet
QuickVet's Avatar
Default Re: I finally did it! (SCVetteGuy)
i used to use mine on large enterance ramps onto the highway. I would pull over and watch for a break in traffic. get onto the highway real quick and stop , set the thing, and go....
much easier to do at night. Not very safe tho.
Old 07-27-2003, 06:48 PM
Raydon 3000
Raydon 3000's Avatar
:party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party: :party:
Old 07-27-2003, 08:18 PM
Ryan77
Ryan77's Avatar
I'm not yet, but hopefully I will be when my 525hp AR 383 arrives any day now :D :cool:
Old 07-27-2003, 08:49 PM
Dwayne 76
Dwayne 76's Avatar
:D
Old 07-27-2003, 08:57 PM
shotgun_000
:seeya SCVetteGuy!
Do you know where Fairforest Middle School is? If so, go past it headed toward I-85. After about a mile, you will cross over I-85. Just keep straight.
After about another mile, there is a road on the left called either leisure road or casual, I can't remember for sure. Anyway, it has a No Outlet sign at the beginning. Just go down that road, you'll find a good spot past where the old school buses are. I've never encounted traffic there before, although it does run parallel to I-85 Southbound lane.
I've went there before, running for an hour at a time. I even took my timing light to "test and tune"
There are some other spots, but that is the most secluded in the immediate area.
Old 07-27-2003, 09:33 PM
SCVetteGuy
SCVetteGuy's Avatar
Thanks Shotgun, The only places I know of aren't very long, and they're sometimes busy. I'll see if I can find where you're talking about, and do some runs. :cool: :D
Old 07-29-2003, 11:19 PM
SCVetteGuy
SCVetteGuy's Avatar
Just got back from doing some runs. Thanks for the info Shotgun, it was a little hard to find it, but we did. and my times were much better 0-60: 7.6 sec. and HP: 166
To I finally did it!
Quick Reply: I finally did it!
