Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-04-2003, 11:42 PM   #1
RMS73
CF Senior Member
RMS73's Avatar
Default Tunnel Insulation
Can the tunnel insulation piece be installed with the transmission in place?
Drove the car up on ramps to do this today and I don't believe it can be done or at least not with the car only raised 6".
Roger
RMS73 is offline   Reply With Quote
Old 07-04-2003, 11:52 PM   #2
A C
CF Senior Member
Cruise-In II Veteran
A C's Avatar
Send a message via AIM to A C
Default Re: Tunnel Insulation (RMS73)
No. It's too big. I thought about it too, but after rolling my creeper under the car, it's pretty obvious that it wont work. I ended up swapping trannies anyway, so it was no big deal then. If you do end up removing the trans to put in the insulation, you might want to check the condition of the battery cable too. It sits between the insulation and the trans, and you would have easy access to it if you have the trans removed. It's not as hard as you think to pull the trans. I also added Dynamat Extreme to the interior floor of my car...but I can't comment on how well it works yet. Good luck with whatever you choose to do. :cheers:
A C is offline   Reply With Quote
Old 07-05-2003, 12:33 AM   #3
LFZ
CF Senior Member
LFZ's Avatar
tunnel insulations are indeed helpful...i replaced mine when i had the motor out..what a big difference between that old beaten worn down one, and new one.
LFZ is offline   Reply With Quote
Old 07-05-2003, 01:34 AM   #4
flynhi
CF Senior Member
The OE "insulation" is really a reflector. You should have one but if you really want to control tunnel heat, add insulation over and around the hump under the carpet. Koolmat is best but most expensive. Several have used reflective foil insulation from Home Depot or Lowes.
flynhi is offline   Reply With Quote
Reload this Page Tunnel Insulation
Tags
2002, adding, c5, corvette, insulation, tunnel, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
KoolMat Heatmaster tunnel insulation, worth it?? Gonzo C5 Z06 Discussion 14 01-31-2004 01:20 PM
Tunnel Insulation Insanity GATOR454 C3 Tech/Performance 12 01-27-2004 07:08 PM
Transmission tunnel insulation jbroughton C3 Tech/Performance 13 12-24-2002 06:03 AM
63 Tunnel insulation question achapman C1 & C2 Corvettes 22 09-30-2002 02:06 PM
L.A.P.D. Tunnel Insulation Hex29A C5 Tech 11 11-26-2001 11:42 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
