Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-04-2003, 11:24 PM   #1
74 vert
CF Senior Member
74 vert's Avatar
Location: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Default Holy Shi@. just about knocked the car into the garage wall.
I've been posting problems with my electrical system. I found a box on the car with a rubber push button on it and pushed it, the car was in reverse and fired and about went into a wall in the garage. The box is mounted on the passenger side andhas a rubber cover and I pushed it. Any of you guys have that? I think it's a breaker. Should I take her out of gear and try it again? Damn, I need to take a picture of this thing. :eek: :eek:
Actually, I tried it again out of gear, I don't think if fired, perhaps my mallory module is toast. I wonder if the Mallory module toasting could cause everything else to be out?
[Modified by 74 vert, 9:25 PM 7/4/2003]
[Modified by 74 vert, 10:24 PM 7/4/2003]
74 vert is offline   Reply With Quote
Old 07-04-2003, 11:26 PM   #2
LAvetteman
CF Senior Member
St. Jude Contributor
Default Re: Holy Shi@. just about knocked the car into the garage wall. (74 vert)
Please do, haven't a clue what you are talking about. :eek:
LAvetteman is offline   Reply With Quote
Old 07-04-2003, 11:33 PM   #3
A C
CF Senior Member
Cruise-In II Veteran
A C's Avatar
Send a message via AIM to A C
Default Re: Holy Shi@. just about knocked the car into the garage wall. (LAvetteman)
Sounds like a previous owner may have rigged up a remote starter switch.
A C is offline   Reply With Quote
Old 07-05-2003, 12:01 AM   #4
74 vert
CF Senior Member
74 vert's Avatar
Default Re: Holy Shi@. just about knocked the car into the garage wall. (A C)
http://www.hpphoto.com/servlet/com.h...84564553596277
Let me know if you can see these pics. I'm having trouble with my usual provider.
Old 07-05-2003, 12:07 AM   #5
JB
CF Senior Member
JB's Avatar
:iagree: Nice thing to have, actually.
JB
[Modified by JB, 10:09 PM 7/4/2003]
JB is offline   Reply With Quote
Old 07-05-2003, 12:09 AM   #6
74 vert
CF Senior Member
74 vert's Avatar
Default Re: Holy Shi@. just about knocked the car into the garage wall. (JB)
why would someone want to do that?
Old 07-05-2003, 12:12 AM   #7
JB
CF Senior Member
JB's Avatar
Makes it easier to work on the engine by yourself. Don't need anyone to bump it over for you to set the points or get it to TDC, and you can start it and kill it as needed as you work without having to climb in and out of the car.
JB
[Modified by JB, 10:13 PM 7/4/2003]
Old 07-05-2003, 12:16 AM   #8
goinbroke
CF Senior Member
goinbroke's Avatar
There is a seatbelt interlock override switch mounted to the passenger side firewall, but it shouldn't do what you described. Its a small metal box with a button sticking out of it.
I couldn't see your pics.
goinbroke is offline   Reply With Quote
Old 07-05-2003, 12:21 AM   #9
Crash Dummy
CF Senior Member
Crash Dummy's Avatar
It does sound like the previous owner wired in a remote starter switch that bypasses the neutral safety switch. When using these things disconnect the coil wire to make sure there is no fire.
Crash Dummy is offline   Reply With Quote
Reload this Page Holy Shi@. just about knocked the car into the garage wall.
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
