Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-04-2003, 07:45 PM   #1
74 vert
CF Senior Member
74 vert's Avatar
Location: Smoky Mountain Cruisers, Not Correctly Restored Stingray
Default dreaded electrical problem
I was out for a drive today, stop at Buddy's BBQ eat and jump back into the car, guess what no go go. The electrical system was not giving me anything, no lights, no hazards, no buzzer, nothin'. I messed with the battery cables, as I have had a loose connection there before, the usual wiggle didn't work this time. :cry Well $50.00 bucks later for a tow and it's now in the garage. I used a voltmeter and determined that I have 12 volts at the battery, but nothing works, no juice. I'm not a corvette electrical guru, what do you guys suggest I check next?
74 vert is offline   Reply With Quote
Old 07-04-2003, 08:35 PM   #2
Boofers
CF Senior Member
Boofers's Avatar
Location: Winner of the 2006 cotter pin bending championship in Hamilton Ontario
Default Re: dreaded electrical problem (74 vert)
So your battery has 12V but nothing in your car works...
The battery +ve runs via a big thick cable to the starter solenoid. From there the power for the entire car runs via a smaller wire, through a fuseable link (fancy name for a fuse), to everything else. Measure your voltage from your starter to the frame, should be the same reading as what you read right at your battery. If its less then check your connections at your battery. The battery grounds right to the frame so make sure that connection is clean as well. If you have any dirt or oxidation on any electrical connections use a file or sand paper to make your connection shiny.
If you read a nice 12V at your starter the next thing to check is the fuseable link. Not sure about your year vette but most fuseable links are inline with this power wire, a small white plastic cylinder thingie. Sometimes the fuseable link sits right in the firewall. You can strip some wire insulation off after the link to measure, or if you don't like that idea find where this wire runs to and measure for 12V. If no 12V after the link but yes 12V before the link you have a bad fuseable link.
Make sure you post a follow up and let us know what you find. Good luck! :conehead
Boofers is offline   Reply With Quote
Old 07-04-2003, 08:36 PM   #3
hiyosilver
CF Senior Member
hiyosilver's Avatar
Since you have done the obvious i would look at the starter solenoid and the wiring going to it .Good Luck.If all that looks good could possibly be ignition module
hiyosilver is offline   Reply With Quote
Reload this Page dreaded electrical problem
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Steering Column Lock FAQs - please read before you post (sticky please) Cscokd C5 Tech 1080 03-10-2010 11:45 AM
Steering Column Lock FAQs Part II Cscokd C5 Tech 26 10-07-2005 05:35 AM
[85 LCD] The Dreaded Intermittent Electrical Problem j3studio C4 Tech/Performance 18 08-18-2004 10:00 PM
'01 Z06 wont start, but electrical does..... JuiceZ06 C5 Tech 11 06-28-2004 05:23 PM
Electrical Help Bobchad C3 Tech/Performance 20 06-26-2003 03:46 AM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
