Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-04-2003, 07:05 PM   #1
five-boy-mom
CF Senior Member
five-boy-mom's Avatar
Default Knocks and clunks with gear changes
OK, I'm scared to ask. I've been hearing a knock, sounds like it comes from the rear axle, for a bit...but now it has turned into a knock just a second after I've shifted gears and accelerate. I hear it when I decelerate sometimes too. You with experience...what am I looking at?
five-boy-mom is offline   Reply With Quote
Old 07-04-2003, 07:13 PM   #2
Hobbes Blk '80
CF Senior Member
Hobbes Blk '80's Avatar
Default Re: Knocks and clunks with gear changes (five-boy-mom)
My '80 doesn't quite pull the same antics to that degree, however I do have a clunk when I go into reverse in the diff area for sure. I also have a slightly less loud clunk when putting the car in drive, but not on shifts or deceleration.
My Mechanic team (my dad and his brother and myself) have a hunch that it is a U-joint coming off of the driveshaft, or one of the halfshafts.. good luck.
Hobbes Blk '80 is offline   Reply With Quote
Old 07-04-2003, 07:32 PM   #3
five-boy-mom
CF Senior Member
Default Re: Knocks and clunks with gear changes (Hobbes Blk '80)
Thanks for the reply. I forgot to mention that it doesn't happen all the time. I've just been hearing it for the past two or three days and then only off and on.
Old 07-04-2003, 08:13 PM   #4
88'Cubka
CF Senior Member
St. Jude Donor '08
88'Cubka's Avatar
Send a message via AIM to 88'Cubka
Get a clean magnet stick and get it to the bottom of the diff. If its covered in filings you will know. Also possible that the play on the yokes are bad. A lot of things it could be. Prolly check the ujoints first.
David
88'Cubka is offline   Reply With Quote
Old 07-04-2003, 10:25 PM   #5
NorthVette
CF Senior Member
NorthVette's Avatar
Send a message via MSN to NorthVette
Check all your U-joints, make sure they are all tight and also check the diff. cushion at the front mounting point... If it is worn or slack it will knock, thud or clunk when your drivetrain slackens and returns to tension (like changing gears)...
Let us know what you found, and good luck!
NorthVette is offline   Reply With Quote
Old 07-05-2003, 01:26 AM   #6
five-boy-mom
CF Senior Member
Default Re: Knocks and clunks with gear changes (NorthVette)
I love this site! You guys are always so helpful! Thanks!!! ;) Oh, and I forgot to add, sometimes there is a little jingling noise as I cruise along...definitely coming from the underside, not the engine.
[Modified by five-boy-mom, 5:27 AM 7/5/2003]
Reload this Page Knocks and clunks with gear changes
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
