Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-04-2003, 11:17 AM   #1
JB
CF Senior Member
St. Jude Contributor
JB's Avatar
Default Parts interchange for harmonic balancer?
Anyone know if the balancer on the '69 big block was used on other Chevy BBs? I've been looking at Chevelle & Camaro balancers on ebay--
JB
JB is offline   Reply With Quote
Old 07-04-2003, 11:22 AM   #2
Paranoid
CF Senior Member
St. Jude Donor '09
Support Corvetteforum!
1970 Chevrolet Corvette
Paranoid's Avatar
Location: 1.Just because I'm paranoid doesn't mean people aren't out to get me... 2. That which does not kill me will probably hurt like hell.....3.Commies are in the WhiteHouse.
Send a message via AIM to Paranoid
Default Re: Parts interchange for harmonic balancer? (JB)
When I bought a new one for the 454, there was no specification as to Chevy model or year. They had ad one listing Chevy BBI think it's 8 inches in diameter. I think I paid $59 from Competition Products.
Paranoid is offline   Reply With Quote
Old 07-04-2003, 12:08 PM   #3
mapman
CF Senior Member
PN 3879623 - 8" Torsional Damper is available from GM Performance Parts. I believe it was what originally came on 1967-69 427 engines.
mapman is offline   Reply With Quote
Old 07-04-2003, 12:59 PM   #4
JB
CF Senior Member
JB's Avatar
Default Re: Parts interchange for harmonic balancer? (mapman)
I wonder if it looks like the original part? The reason I'm looking at the Chevelle & Camaro balancers is I'd like a balancer that looked original, and maybe even was dated coded correctly. If a part has the word "corvette" attached to it on ebay, the bidding tends to go through the roof--Camaro and Chevelle parts seem to go a little more reasonably, and if a balancer from something like a SB Nova or something would fit and look right, I could probably get it for a song.
JB
Old 07-04-2003, 02:31 PM   #5
mapman
CF Senior Member
I wonder if it looks like the original part? ....
The description in the 2003 GMPP catalog page 129, says "This 8" diameter torsional damper is designed for all internally balanced big block V8s. It was originally used on 1967-69 427 ci engines."
They also specify to use damper with crankshaft pn 3967811 and chromed timing pointer pn 12342001. I think the crankshaft in your 69 may be 3882849 (427 - Except Special High Performance HD Aluminum cyl and case)
In that case the damper would be pn 3860008 (1965-69 396,427 except Special high performance HD Aluminum cyl and case)
PN 3860008 is available new from your Chevy dealer as GM Restoration Parts.
Old 07-04-2003, 06:26 PM   #6
Paranoid
CF Senior Member
St. Jude Donor '09
Paranoid's Avatar
I check the '68-82 parts inter-change book and it looks like they list all '66-72, 396-427's Passenger & Hi-Po's and some 400's as using the same balancer. Starting in 1970 they list the 454's separate. Can't imagine what the difference is----Is the 427 internally balanced? The 454 Mark IV is externally balanced. :chevy
[Modified by 1970 Stingray, 6:28 PM 7/4/2003]
Reload this Page Parts interchange for harmonic balancer?
Tags
3860008, 3879623, balancer, gm, harmonic
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 79 12-22-2009 04:58 PM
Anybody Running a 400 small block? KYVette90 C4 Tech/Performance 28 11-21-2001 12:06 AM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
