Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-04-2003, 09:50 AM   #1
MotorHead
CF Senior Member
1980 Chevrolet Corvette
MotorHead's Avatar
Location: Mississauga, Ont. Why don't you ever see the headline 'Psychic Wins Lottery'?
Default Ordering oil pan looking for suggestions
I am going to order an oil pan for my "80 L48 and I would like to know what aftermarket pans anyone has installed kind of leaning toward a side kickout higher volume pan as I am going to be building a 400 stroker in the near future in the 420 - 434 range but and regular volume pan would also be OK right at the moment.
Part numbers would be helpful :D
MotorHead is offline   Reply With Quote
Old 07-04-2003, 09:53 AM   #2
gdh
CF Senior Member
Default Re: Ordering oil pan looking for suggestions (MotorHead)
Have you looked at some of the Milodan pans, I think that one of their different pans should fit quite nicely.
gdh is offline   Reply With Quote
Old 07-04-2003, 02:50 PM   #3
The Money Pit
CF Senior Member
The Money Pit's Avatar
Default Re: Ordering oil pan looking for suggestions (gdh)
I run a Moroso 7 qt kick out style pan,and have had good luck with it. Plenty of clearance,and no leaks.
The Money Pit is offline   Reply With Quote
Old 07-04-2003, 03:20 PM   #4
Racer16k
CF Senior Member
Racer16k's Avatar
I've got a 7 qt. Moroso road race type pan. It works well, but if you are building a 430 later on you need to make sure the pan rail has bump outs for rod clearance. Most race pans do, but not all. Check out Canton oil pans. They have some nice wet sump pans, most are cadium plated. Also if you are using a big block pump, you would want to check for clearance.
Racer16k is offline   Reply With Quote
Old 07-04-2003, 05:48 PM   #5
914eener
CF Senior Member
914eener's Avatar
Default Re: Ordering oil pan looking for suggestions (Racer16k)
I'm using a a 7qt Milodon. The first one I got had a leak where the seams had been welded. Sent it back to Summit and got another one. Had to install a windage tray as the L81 didn't have one from the factory.
914eener is offline   Reply With Quote
Reload this Page Ordering oil pan looking for suggestions
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
