Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-04-2003, 10:29 AM   #1
nada
CF Senior Member
nada's Avatar
Default Found a down side to the big block cars!
Issue resolved
[Modified by Rick Church, 12:23 AM 7/16/2003]
nada is offline   Reply With Quote
Old 07-04-2003, 10:36 AM   #2
OHSIXX
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-10-'11-'12
Support Corvetteforum!
OHSIXX's Avatar
Default Re: Found a down side to the big block cars! (Rick Church)
My 350 can get pretty hot sometimes in Florida; especially with the Astro Top.
I rarely use the AC, so it must not be to bad.
OHSIXX is offline   Reply With Quote
Old 07-04-2003, 10:42 AM   #3
Jughead
Senior Member since 1492
St. Jude Donor '09
Jughead's Avatar
Location: 1.Just because I'm paranoid doesn't mean people aren't out to get me... 2.That which does not kill me will probably hurt like hell...3.Spare me the Lima Beans.
Send a message via AIM to Jughead
That's not a down side Rich....my wife & I plan to loose a few lbs every outing. :lol: Sorta like a sauna with your clothes on, I told her, :D
Jughead is offline   Reply With Quote
Old 07-04-2003, 11:20 AM   #4
JB
CF Senior Member
St. Jude Contributor
JB's Avatar
Default Re: Found a down side to the big block cars! (1970 Stingray)
Hmm. I've never really noticed that's it's hotter in my BB than in the SB I used to have. Both of 'em would give me toasty feet, but nothing so bad I felt abused. And my rat never overheats. Just did a 140 mile run a couple weekends back (70 miles each way with a few hours break in between) in 95 degree weather and she ran 190 the whole way.
JB
JB is offline   Reply With Quote
Old 07-04-2003, 11:21 AM   #5
bamavettes
CF Senior Member
bamavettes's Avatar
I have driven many big blocks for a lot of years. Had a 70 that would toast me.
This '68 427 Big Block below is a pleasure to drive. It's no hotter than a 350. I feel like it is a honor every week when I drive it.
I was not looking for a car with good gas mileage. My wife has one of those.
These cars have been called Shake-Rattle-and Roll. If you can get past #1 and #2 then all is fine.
Have a great 4th.....
bamavettes is offline   Reply With Quote
Old 07-04-2003, 11:36 AM   #6
Alwyn678
CF Senior Member
Alwyn678's Avatar
BB's do get hotter but who the hell uses the A/C in a vette..........I like putting the top down and feeling the wind in my hair.plus I want all the extra horses I can get......... :cheers:
[Modified by Alwyn678, 12:01 PM 7/4/2003]
Alwyn678 is offline   Reply With Quote
Old 07-04-2003, 11:50 AM   #7
fontking1a
CF Senior Member
fontking1a's Avatar
Rick...my '69 runs pretty cool and has done so for the past 30 something years. I run a 160 thermostat and the car has no A/C. Heat has never been a problem. California can get pretty hot at times but it's never kept me from driving the car....
Hope to see you in Middle Tennessee in the next year or so. We're leaving this state as soon as we can.....
fontking1a is offline   Reply With Quote
Old 07-04-2003, 12:01 PM   #8
Larry B.
CF Senior Member
Larry B.'s Avatar
I hear about heat all of the time... Any corvette that doesn't have all of the heat insulators and shields and the air doors aren't working just right can get hot. Headers make it worse. Also ... Factory non A/C cars have vent that the A/C cars do not have. So if you have a car with the A/C removed or not working then there are no vents to open. My 69 is not a problem at all even here in Florida... :cool:
Larry B. is offline   Reply With Quote
Old 07-04-2003, 01:32 PM   #9
Rowdy Rat
CF Senior Member
Rowdy Rat's Avatar
Larry,
Too true... Add to that improperly installed/missing grommets, lack of appropriate sealer over grommets/plugs/boots, malfunctioning HVAC controls, damaged shift lever seal... The list goes on. The sealant issue is especially common because restorers don't like to "mess up" a freshly detailed firewall by slopping on the sealant. Ugly or not, it's there for a reason.
I'm with you... I never noticed the big block Corvettes that I've owned to be any hotter in the passenger compartment than the small blocks that I've had... As long as the previously mentioned areas are finished/installed/working up to factory specifications.
Regards,
Rowdy Rat is offline   Reply With Quote
Old 07-04-2003, 01:58 PM   #10
PRNDL
CF Senile Member
PRNDL's Avatar
Mark Jackson @TraderJaxon
Send a message via AIM to PRNDL
Rick, You are on to us! :lol: The trick is to look COOL while you are sweating!! But actually it doesn't have to be quite as bad as what you saw. I have made a lot of progress in making my car bearable in the heat by addressing all those issues mentioned above. A huge difference when the car is running at 185-190 vs 210-220!! At the hotter temps the center console and other areas get hot. But with the top down on a hot sunny day you are going to be hot no matter what you are driving! MJ :)
PRNDL is offline   Reply With Quote
Old 07-04-2003, 02:09 PM   #11
Corey_68
CF Senior Member
Corey_68's Avatar
Default Re: (MNJack)
We've had our '68 for 23yrs and not once have we charged up the A/C. Just drop the top on the Vert and you have instant A/C. :D
Happy Fourth guys, even thouugh it's pouring rain here. :rolleyes:
Corey_68 is offline   Reply With Quote
Old 07-04-2003, 04:18 PM   #12
norvalwilhelm
CF Senior Member
norvalwilhelm's Avatar
I just got back from an hour run at about 70 mph in over 90 degree heat and my car never came close to hitting 200 even in that heat. I don't have air but with the windows down and the Tee tops ON it was a pleasant drive. I also run close to 15 mpg on the open road.
norvalwilhelm is offline   Reply With Quote
Old 07-04-2003, 07:52 PM   #13
74 vert
CF Senior Member
74 vert's Avatar
Location: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Default Re: Found a down side to the big block cars! (norvalwilhelm)
I think my interior temp is much cooler now that I installed, foil covered insulation under the carpet and Jet-hot Hooker side-pipes, the sound is cool too. I have a non-AC car.
74 vert is offline   Reply With Quote
Old 07-04-2003, 08:13 PM   #14
bence13_33
CF Senior Member
bence13_33's Avatar
You're right big blocks do have down sides. All that torque sure is a bummer :D .
Seriously though the gas mileage with my car isn't that bad. I get 8-10MPG since I leaned out my carburetor. The main thing that kills my gas mileage is my 4.11 gears with no overdrive. Taching 3000-3500RPMs at 55-65MPH will do that though. After having built a big block I can honestly say I have no desire to put a small block back in my car.
bence13_33 is offline   Reply With Quote
Old 07-04-2003, 10:16 PM   #15
norvalwilhelm
CF Senior Member
Default Re: Found a down side to the big block cars! (bence13_33)
Shane once you install that blower motor I think you would be better off without the 4.11's. The new motor will make so much torque that they will fry any street tire you try. I reinstalled the 3.08 and like them alot better. At least now in second with a little care it hooks.
Old 07-04-2003, 10:38 PM   #16
zwede
CF Senior Member
zwede's Avatar
I know your post was kidding but I drive my 71 454 every day. AC blows cold 40F air, engine never goes above 200F and I get 12+ mpg city. Now an all stock 71 may not have done the above, which is why I modifed it! :cool:
zwede is offline   Reply With Quote
Old 07-05-2003, 08:46 AM   #17
WESCH
CF Senior Member
WESCH's Avatar
Hi
Sounds like my car when I bought it. 68 convert BB.
It had cracked open floor panels, the shifter linkage tunnel was cut out to work on the links, every plug of the splash /heat shield was missing. The vent fan + box was removed and hot eng compartment air found it's way through, the hood aft seal was missing allowing hot air to get through the fresh air intakes and and and.....
After fixing all this + installing alu-rad, elctric rad cooling fans, adjusting ign timing correctly and and and..., its just a pleasure to drive now.
No more hot feet, no more hot air blowing into my face.
And I don't even have AC . :crazy:
I realy also need to wrap the HOOKER side pipe headers to finish this up.
BB rocks. I wouldn't miss it anymore.
Gunther
WESCH is offline   Reply With Quote
Old 07-05-2003, 09:14 AM   #18
Marc80
CF Senior Member
Do like I do in Florida ...throw in a chunk of aromatic cedar. It will really complete the sauna illusion!
Marc80 is offline   Reply With Quote
Reload this Page Found a down side to the big block cars!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 82 09-15-2011 12:07 PM
A Forum Cruise In Road Trip Tale... 427Hotrod C3 General 12 06-03-2005 07:57 AM
What can I tell the owner of a 1967 Big Block (in storage) to show his car? JJU C1 & C2 Corvettes 20 03-22-2002 10:06 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
