Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-04-2003, 04:06 AM   #1
Chuck Harmon
CF Senior Member
Chuck Harmon's Avatar
Default Crossmember is Out!
The surgery is done and I believe a success! Hardly a scratch to my floor pan from the blade. I had bought two packs of blades, 6" and 9". I ended up needing one about 7.5" for the final cut. Of course the stores are now closed. Thankfully Bubba happened to stop by and helped me cut a 9" blade done to size with the Sawzall. Perfect. For marking the cut, I used red duct tape on both sides of the line I scribed across the bottom of the crossmember. The tape wrapped up the sides and over the top and stayed very square. I suppose one could use a different color, but the red fit the mood for the occasion.
Once I get the engine and trans out, I will fabricate the saddle for re-installation. I intend to use a length of thick sidewall pipe (slightly larger inside diameter of the bolt used to secure the bracket) inside each outboard portion of the crossmember so that I won't crush the crossmember when I torque up the bolts securing the center section. I think Chevy uses this same idea within the frame where the steering box bolts up.
Thanks to everyone for your great help, pictures, suggestions, and most of all - encouragement! More pictures will follow as my work continues.
Chuck
[Modified by Chuck Harmon, 12:08 AM 7/4/2003]
Chuck Harmon is offline   Reply With Quote
Old 07-04-2003, 06:08 AM   #2
Shark Racer
CF Senior Member
Shark Racer's Avatar
Send a message via ICQ to Shark Racer Send a message via AIM to Shark Racer
Default Re: Crossmember is Out! (Chuck Harmon)
Awesome work, Chuck.
See you tomorrow after my early morning date with the Austrian Oak.
We'll see how long it takes me to do a rear spring and shock swap!
I just hope you have a 9/16" socket to get those center spring bolts off with. If not, I may have some at home I can bring.
-Steve
[Modified by Pacin'California, 2:08 AM 7/4/2003]
Shark Racer is offline   Reply With Quote
Old 07-04-2003, 08:57 AM   #3
SmokedTires
CF Senior Member
Cruise-In III Veteran
St. Jude Donor '05
SmokedTires's Avatar
:hurray: The tough part is done, the rest should be a piece of cake :thumbs: .
SmokedTires is offline   Reply With Quote
Old 07-04-2003, 11:36 AM   #4
tsw71
CF Senior Member
tsw71's Avatar
Chuck, I can't belive you actually cut your car :nonod: I was only kidding when I said you should do it :jester :jester
Seriously though. Like the old saying goes..... Anyone can restore a car, but it takes a real man to cut one up!!
Nice job! The cuts look very straight too :thumbs:
tsw71 is offline   Reply With Quote
Old 07-04-2003, 04:35 PM   #5
mrvette
CF Senior Member
mrvette's Avatar
You know, Chuck, We all needed to see the look on your face watching that first stroke of the sawzall into that frame....musta been gruesome!!!
kinda like reaching for the soap in the shower....
GENE :D :D :lolg: :lolg: :lolg:
not downing YOU per se....I felt the same way....
mrvette is online now   Reply With Quote
Old 07-05-2003, 12:47 AM   #6
Chuck Harmon
CF Senior Member
Default Re: Crossmember is Out! (mrvette)
Gene,
As it turned out, it was my second cut. I found an unsuspecting c3 with Florida plates and practiced on it first.
:lol:
Chuck
Old 07-05-2003, 07:14 AM   #7
mrvette
CF Senior Member
mrvette's Avatar
OH NO, this car WAS expecting it, but I did not know what to expect upon doing the cut, things like frame loading, maybe a rail twist due to being jacked but none of that happened, I still like the angle iron layed on top rear and drilled through with bolts, and a bottom flange also....making the center slide to the rear for removal...it does not leave the bolts alone to hold any twist or weight loading, but acts to keep the loading off the bolts....but of course it can only be welded on the rear section, anything in front needs be bolted , obviously...
GENE
Reload this Page Crossmember is Out!
Tags
2003, corvette, crossmember, diameter, inside
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Richmond 6speed install LFZ C3 Tech/Performance 15 03-10-2005 03:12 PM
crossmember is out. WESCH C3 Tech/Performance 10 03-02-2005 08:57 AM
Which supercharger fits underneath L88 hood? peterbx1 C3 Tech/Performance 34 11-29-2004 05:27 PM
removing crossmember...hints? pix? and what about the emerg brake cable pully? OkeeGuy C3 Tech/Performance 32 01-10-2004 01:38 AM
my frame is breaking, i've heard this is common... radwebster C3 Tech/Performance 18 03-27-2003 04:23 PM
Mouse motor is out! Bob Turner C3 Tech/Performance 16 10-08-2002 07:50 PM
motor,trans, and exuast is out of the car(pics) PatsLs1vette C3 Tech/Performance 11 07-29-2002 09:43 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
