Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-04-2003, 12:05 AM   #1
WPEDirect
CF Senior Member
Default Climate Controls
I'm sure everyone is familiar with the controls, but mine has the dual 'vertical dials' between the shifter and radio. The drivers side wheel turns with more pressure than it should take, but the passenger side doesn't move at all. Is it supposed to?
WPEDirect is offline   Reply With Quote
Old 07-04-2003, 01:29 AM   #2
Diode
CF Member
Diode's Avatar
Default Re: Climate Controls (WPEDirect)
Both of them should move relatively easily. Keep in mind that both of them are connected to cables as well as vacuum switches. Chances are that the one that doesn't move has a frozen cable. The cable on the right one controls the 'deicer' door down in the plenum. The cable on the left one controls the heater temp control door (also in the plenum).
Diode is offline   Reply With Quote
Reload this Page Climate Controls
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
90 heater problem... it stays on !!! flyingVplayer C4 General Discussion 10 05-15-2005 11:14 PM
95 LT1 - temp replacing the '85 I flipped - more info on the '95 and Climate controls --> 85Procharged383 C4 Tech/Performance 11 02-10-2004 02:06 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
