Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-03-2003, 11:27 PM   #1
Eddie 70
CF Senior Member
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Support Corvetteforum!
Eddie 70's Avatar
Default Non PB Master Cylinder Removal.
Some one else started me thinking. I have a leak in my vacuum tank reservoir. I need to remove it to try to fix it. In order to remove it I have to pull the master cylinder. I don't have PB, how hard would it be to remove the master cylinder and are there any tricks or pitfalls I should be aware of?
Thanks for any help!!
Eddie 70 is offline   Reply With Quote
Old 07-04-2003, 01:24 AM   #2
ORVette
CF Senior Member
ORVette's Avatar
Default Re: Non PB Master Cylinder Removal. (Eddie 70)
Go to an auto parts and get a cheap set of plugs for the MC, usually included in inexpensive "one-man" bleeder kits or MC bleed kits. I think I gave a few bucks for mine. As long as you don't let the thing leak completely dry, you won't have to re-bench bleed it. You will have to bleed the lines though. If you're using organic brake fluid, remember to treat it just as you would paint stripper.
ORVette is offline   Reply With Quote
Old 07-04-2003, 10:05 PM   #3
Eddie 70
CF Senior Member
Eddie 70's Avatar
Default Re: Non PB Master Cylinder Removal. (ORVette)
Can I just take the master cylinder loose from the firewall and pull it out of the way far enough to remove the reservoir tank without breaking the lines loose?
Reload this Page Non PB Master Cylinder Removal.
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
