Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-03-2003, 10:43 PM   #1
69 LT1
CF Member
69 LT1's Avatar
Default Tight fit
Has anybody been able to pull out the vacuum tank on a 69 without pulling the brake booster,
And would solder work to patch a hole or must it be welded
Or should I just do a buba and by the smaller 80-82 can and put it on the other wheel well.
69 LT1 is offline   Reply With Quote
Old 07-03-2003, 10:52 PM   #2
LAvetteman
CF Senior Member
St. Jude Contributor
Default Re: Tight fit (69 LT1)
I wouldn't waste my time on solder. Solder can be very finicky on where it sticks. JB Weld would hold up fine in that application.
LAvetteman is offline   Reply With Quote
Old 07-03-2003, 10:54 PM   #3
A C
CF Senior Member
Cruise-In II Veteran
A C's Avatar
Send a message via AIM to A C
My dad used to own my 69. I just talked to him. He just looked at the tank and it had so many holes in it that it was shot. I suppose from water collecting in the bottom of it.
He does remember having to pull the brake booster. He said he remembers using lots of u-joints on the socket extensions. He also said he read articles saying you would have to pull the inner fender off, but he didn't have to.
[Modified by A C, 9:16 PM 7/3/2003]
A C is offline   Reply With Quote
Old 07-03-2003, 11:25 PM   #4
Eddie 70
CF Senior Member
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Support Corvetteforum!
Eddie 70's Avatar
Default Re: Tight fit (A C)
My tank leaks too. I tried to pull mine without removing the master cylinder and I couldn't do it. Maybe I should give it another go.
Eddie 70 is offline   Reply With Quote
Old 07-03-2003, 11:31 PM   #5
A C
CF Senior Member
A C's Avatar
Default Re: Tight fit (Eddie 70)
Maybe you misread my post...dad said he definitely did have to pull the master cylinder and brake booster. It was even kind of a pain in the butt after that, he said. He got one from, he believes, a 76. The tanks are very similar up to a certain model year. I can't remember which year it is though. I do remember when he went through this...none of the vacuum parts worked worth a crap! :lol:
I remember when he had a huge Crower cam in the car, he used to make me get out and lift up the headlight buckets. :lol:
Old 07-04-2003, 01:26 AM   #6
69 LT1
CF Member
69 LT1's Avatar
There's definitely not enough room with the master there, I was hopeing it would come out with the master removed but the booster still on,
I know i have a hole towards the top on the wheel well side, I think I'll unbolt it and see if I get good access to the hole and sand it and put some J-B weld on it, Maybe I'll get lucky and not have to pull it all the way out.
Old 07-04-2003, 05:33 PM   #7
69 LT1
CF Member
69 LT1's Avatar
Well It took me about an hour 1/2 but I got it out, The booster must come out, The bottom bolts are ok, the top ones were a B*tch, Long extension with a swivel socket on the end and the air ratchet,
Now should I go to radiator shop or a body shop to get it fixed, I really don't wand to try JB weld Cause I don't want to have to pull it again,
I'm also going to replace the booster seal on the master side, Does it just sit there were it belongs or should I put some silicone or something to hold it from moving
Old 07-04-2003, 06:02 PM   #8
bence13_33
CF Senior Member
bence13_33's Avatar
Yikes. The one in my 1976 Corvette is A LOT smaller than that. I was able to remove mine without moving anything else.
[Modified by bence13_33, 4:05 PM 7/4/2003]
bence13_33 is offline   Reply With Quote
Reload this Page Tight fit
Tags
corvette, fit, tight
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tight Fit, Excellent Quality.... THECORVETTEMANN C6 Corvette General Discussion 27 02-02-2005 11:22 AM
Good to have a nice size garage / tight fit :D GrandSportC3 C3 Tech/Performance 15 12-12-2004 03:40 PM
Is anybody else 6'4"? Can I fit? Corvettebiten C1 & C2 Corvettes 21 12-04-2004 09:05 PM
keisler tranny is a real tight fit panchop C1 & C2 Corvettes 11 11-17-2004 12:58 AM
Does a 215 width tire fit in a midyear spare tire tub? LouieM C1 & C2 Corvettes 24 05-08-2004 12:27 AM
Midas now says a 3" exhaust won't fit under a C-3,Need pics to show otherwise. The Money Pit C3 Tech/Performance 25 06-06-2003 10:07 PM
What are the widest rear tires I can fit on my 98 without tubbing?? LPDesRoche C5 Tech 13 04-01-2003 02:49 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
