Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-03-2003, 02:02 PM   #1
Matt Gruber
CF Senior Member
Default How to remove the cam with the radiator still in the car
Let's see if anybody can figure out what i have in mind.
Matt Gruber is offline   Reply With Quote
Old 07-03-2003, 02:50 PM   #2
Fevre
CF Senior Member
Fevre's Avatar
Default Re: How to remove the cam with the radiator still in the car (Matt Gruber)
I'll guess: heard of people unbolting the mounts and lifting/jacking the eng up just far enough so the cam clears the rad when pulled out.
Fevre is offline   Reply With Quote
Old 07-03-2003, 02:57 PM   #3
Matt Gruber
CF Senior Member
This trick is for sombody that wants to try several cams and have a good laugh in the process. As patsnitrovette pointed out, you can avoid loosening the oil pan by cutting off the ears of the timing cover. and gkull has a 2 piece cover. Now, if we could leave the radiator in, think how fast you could change cams!
I have a spare rad, i'll never use is, so why not cut a beer can size hole in it where the cam wants to escape? solder shut the tubes. it will lose some capacity, but who cares, this is for cam testing and grins.
Plug the hole with a BEER CAN! Now go to the track, and car shows and complain how some SOB tossed a beer can out the window and it went right thru your rad! And how you are afraid to take it out 'cause it will leak for sure.
:lolg:
Old 07-03-2003, 03:01 PM   #4
PatsLs1vette
CF Senior Member
PatsLs1vette's Avatar
Thats a good one :thumbs: your always thinking :cheers:
PatsLs1vette is offline   Reply With Quote
Old 07-03-2003, 04:36 PM   #5
Fevre
CF Senior Member
Fevre's Avatar
Matt
I sometimes think you have too much time on yours hands. :)
Old 07-03-2003, 05:42 PM   #6
Chinaski
CF Senior Member
Chinaski's Avatar
Location: "Our democracy will cease to exist when you take away from those who are willing to work and give to those who would not." - Thomas Jefferson
:lolg:
:lol: :lol: :lol:
Chinaski is offline   Reply With Quote
Old 07-03-2003, 06:21 PM   #7
The Dude
CF Senior Member
The Dude's Avatar
Get up into the wheel wells and remove the bolts holding the top of the core support. You may also have to loosen the bolts at the bottom. Anyhow, what you want to do is tip the radiator up and out of the way. But you may have to remove your hood to get clearance to do this. And, if you're already loosening all those bolts, you may just want to go ahead and take the thing out.
The Dude is offline   Reply With Quote
Old 07-03-2003, 07:16 PM   #8
isosceles
CF Senior Member
isosceles's Avatar
Good thinking Matt! Are you going to try it? :smash:
isosceles is offline   Reply With Quote
Old 07-03-2003, 07:21 PM   #9
Twin_Turbo
CF Senior Member
Default Re: How to remove the cam with the radiator still in the car (isosceles)
apart from rad, fastest way to swap cams is by using 2 pc cover w/ gear drive (no need to remove chains there) and a roller cam w/ spring loaded rollers (horizontal bar), when you loosen the rockers the rollers will be pushed up, remove \timing cover lid and pull cam. If you run a dry sump and a crank trigger it's even better, no distr. pulling then.
Twin_Turbo is offline   Reply With Quote
Old 07-03-2003, 08:29 PM   #10
Matt Gruber
CF Senior Member
this is one of my "too much time on my hands" ideas like Fevre says.
The best part is the fun showing poeple the beer can stuck in the rad. Reminds me of fake legs poeple stick under their cars, except this could really fool many; i could damage my face from too much laughing. :)
Like rick church says AC cars=NO
I am on my 4th cam, i like #4, but there might be someone out there that might want to have some fun with this crazy idea. It is really not a time saver. Leaving the oil pan tight is a big time saver.
Happy 4th :seeya
Old 07-04-2003, 12:15 PM   #11
SanDiegoPaul
CF Senior Member
Support Corvetteforum!
SanDiegoPaul's Avatar
Location: San Diego - Deep Within The State of CONFUSION!
In my first car, a '57 Bel Air many moons ago I put in a new motor. The vacuum tap at the back of the intake was missing and when I was ready to fire her up for the first time I needed something to plug the hole. My buddy gave me a spark plug and it fit perfectly.
I got laughs for years the guys made fun of my 9-cylinder '57 and always threatened to put a plug wire on that #9 plug! :bb :lolg: :nono:
SanDiegoPaul is offline   Reply With Quote
Old 07-04-2003, 02:58 PM   #12
stingraynick75
CF Senior Member
stingraynick75's Avatar
I found the easiest way.... pull the engine :cheers:
stingraynick75 is offline   Reply With Quote
Old 07-04-2003, 03:17 PM   #13
Dalannex
CF Senior Member
Dalannex's Avatar
I actually worked on a pickup once that had a hole in the radiator from a previous cam swap. :rolleyes: :lol:
-Justin
Dalannex is offline   Reply With Quote
Old 07-04-2003, 04:16 PM   #14
Rockn-Roll
CF Senior Member
Rockn-Roll's Avatar
Doing a cam swap with engine and radiator still in the car is the same job as damaging the radiator...it's probably indexed under both jobs in the mechanics corvette job estimator guide.
You will need to drain the coolant anyway right? Just pull the radiator. I know it's a PITA as I've replaced my fan shroud. In my opinion pulling the engine may be a lot easier than pulling the fan shroud even...much less the radiator, and in my case A/C condenser.
Maybe you could just get rubber cams so you can bend them enough to slip into the engine? Perhaps one of those trick cams that can grow or shrink depending on the amount of air you fill them with? Or, I know...just replace the engine with a 2 stroker that has no valves!
Rockn-Roll is offline   Reply With Quote
Reload this Page How to remove the cam with the radiator still in the car
Tags
cam, car, remove
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 03:23 PM
c5 coupes typically leaky? LSUgoTIGER C5 General 24 09-07-2005 11:24 PM
Help! My goof may have killed my Vette. Borescope needed? OriginalOwner1985z51 C4 Tech/Performance 57 08-07-2005 02:36 PM
? about buying a C5 gmintimidator C5 General 10 03-21-2005 02:37 PM
HO HUM- Threw another cam in this afternoon. Andy@AandACorvette C5 Tech 22 06-25-2002 03:04 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
