Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-03-2003, 01:46 PM   #1
conway62
CF Senior Member
conway62's Avatar
Default A/C question
I got the Air Conditioning working on my 71 but it dies when I place it in the Max AC position. All other positions work fine. Any ideas that could cause the AC Max position not to work?
Thanks in advance :banghead:
conway62 is offline   Reply With Quote
Old 07-03-2003, 01:53 PM   #2
Sun King
CF Senior Member
Sun King's Avatar
Default Re: A/C question (conway62)
What "dies"?
Sun King is offline   Reply With Quote
Old 07-03-2003, 03:43 PM   #3
Rockn-Roll
CF Senior Member
Rockn-Roll's Avatar
If the compressor or the blower stops working then it's the electrical switch. If you just stop getting cool air out of the vents then it's the vacuum switch.
Rockn-Roll is offline   Reply With Quote
Old 07-03-2003, 03:47 PM   #4
dogboy
CF Senior Member
dogboy's Avatar
Default Re: A/C question (Rockn-Roll)
Check the vacum lines that feed into the firewall behind the distributor. They are prone to leaks. and than check them going to the actuators. I'm assuming that you are not getting air through the main vents but the system is working.
dogboy is offline   Reply With Quote
Old 07-03-2003, 11:03 PM   #5
Smokehouse69
CF Senior Member
Cruise-In VI Veteran
Cruise-In VII Veteran
Smokehouse69's Avatar
There is a high blower fuse, it is a 30amp inline fuse. It is located under the hood on top of the drivers-side fender well, near the horn relay. It is supposed only to supply power to the motor when the switch is on high.
It is very common for that fuse to blow.
Good luck!
Smokehouse69 is offline   Reply With Quote
Old 07-04-2003, 09:16 AM   #6
conway62
CF Senior Member
conway62's Avatar
Default Re: A/C question (Sun King)
The compressor dies when turned to the max position. Is there a seperate switch for the Max position?
Old 07-04-2003, 09:42 AM   #7
Larry B.
CF Senior Member
Larry B.'s Avatar
If the Compressor and blower stop in Max then the switch in the control panel is out of adjustment... If just the blower stops in max or high speed.(which may be what's happening) there is an in line fuse in the red wire that runs along the driver's inner fender to the horn relay. If that is good the check the high speed blower relay on the evaporator housing.
Larry B. is offline   Reply With Quote
Old 07-04-2003, 11:13 AM   #8
mrvette
CF Senior Member
mrvette's Avatar
Default Re: A/C question (bluevetteman)
Bluevetteman there nailed it , the fuse holder should be clean and intact too, that white thing next to the horn relay which doubles as the main power distribution point
also, that hi speed blower relay on the a/c is right next to the exhaust manifolds and mine got baked pretty well, you know....off the road, in the garage, hood down glowing cast iron heavy as hell cooks everything in site with NO air movement....well those wires and plug and the relay were moved to a spot on top of the evap housing....be super careful how you do this though place two very SHORT screws well located so as not hit the evaporator and destroy it....;-)))
GENE
mrvette is online now   Reply With Quote
Reload this Page A/C question
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Aftermarket A/C question Subfixer C1 & C2 Corvettes 43 06-15-2005 06:50 PM
A/C question. What freon to use. Veet 66 C1 & C2 Corvettes 16 05-26-2005 04:21 PM
A/C Question 67vetteal C1 & C2 Corvettes 17 09-01-2004 05:49 PM
Simple A/C question..... calee4nyaboy C5 Tech 12 07-24-2004 07:47 PM
A/C Question Koz C3 Tech/Performance 15 04-14-2003 06:14 PM
C4 Mechanics A/C Question Inside.................................................... 69shark C4 Tech/Performance 15 06-13-2002 04:54 PM
A/C question lou C3 Tech/Performance 15 04-23-2002 03:54 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
