Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-02-2003, 11:20 PM   #1
Mike Mercury
CF Senior Member
Mike Mercury's Avatar
Default raise or lower; which is easier.
The wifes 1973 does "squat" ever so slightly in the rear. So little that no one else seems to notice it; but i do.
I would like to change that by either raising the rear or lowering the front. Probably only need to make a 1/2 to 3/4" adjustment.
Is it easier to raise the rear on a C3, or lower the front? And can it be done by simple adjustment (no new parts purchased) ?
Mike Mercury is offline   Reply With Quote
Old 07-02-2003, 11:24 PM   #2
bigblockbob
CF Senior Member
bigblockbob's Avatar
Send a message via AIM to bigblockbob
Default Re: raise or lower; which is easier. (Mike Mercury)
you could cut your front springs... be sure not to use a torch.
bigblockbob is offline   Reply With Quote
Old 07-02-2003, 11:28 PM   #3
BSeery
CF Senior Member
Arizona Events Coordinator
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06
BSeery's Avatar
Location: Murfreesboro, TN Corner of "Bumf*&k and 'You've got a purdy mouth'."
Send a message via AIM to BSeery Send a message via Yahoo to BSeery
Default Re: raise or lower; which is easier. (bigblockbob)
cut 1/2 coil and you should have your drop. Let it settle and drive it a while before doing any more.
Unless your front is too low now, I would lower it instead of raising the rear. The 4x4 look sucks on a C3, and too many of them have it.
BSeery is offline   Reply With Quote
Old 07-03-2003, 03:59 AM   #4
Rockn-Roll
CF Senior Member
Rockn-Roll's Avatar
How are the tires? Are the fronts new and the rear worn? Easiest fix could be some new tires, or if current tread is in good shape then tire size changes. If you have 255/60-15's all the way around then some 245/60-15's on the front will drop the front about 1/2". 235/60-15's would drop it a full inch. If you really want to rake it then get some 245/50-15's to drop the front 2-1/2"!
Rockn-Roll is offline   Reply With Quote
Old 07-03-2003, 09:54 AM   #5
Mike Mercury
CF Senior Member
Default Re: raise or lower; which is easier. (Rockn-Roll)
Quote:
How are the tires?
interesting suggestion. I checked and all the tires seem to have the same tread depth.
I guess I was hoping for something easy... like how easy it is on a C5 to make small adjustments in heigth just by turning a few bolts. I take it that's not the case with a C3 ???
Old 07-03-2003, 10:17 AM   #6
Shark Racer
CF Senior Member
Shark Racer's Avatar
Send a message via ICQ to Shark Racer Send a message via AIM to Shark Racer
You can raise the rear by "tightening" the nuts on the rear spring bolts. The front will require new/modified springs, however.
I used a vice grip to keep the shaft from turning. I'm not sure if this is "bad", the book only describes adjustments as being done in the air.
-Steve
Shark Racer is offline   Reply With Quote
Old 07-03-2003, 08:16 PM   #7
Mike Mercury
CF Senior Member
Default Re: raise or lower; which is easier. (Pacin'California)
-Steve;
Thanks BIG TIME. That was exactly what I was looking for.
I'll give it a try. :cheers:
Reload this Page raise or lower; which is easier.
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 209 03-01-2010 06:38 PM
Need Help N.w. T.b. And Fast Intake Issues LOOKN2GETSTROKED C5 Tech 9 06-27-2005 12:09 PM
Idle transition tuning gojo C5 Scan & Tune 9 02-01-2005 10:53 PM
Heads/Cam or SuperCharge Dirty Howie C5 Tech 51 11-21-2004 10:04 PM
How to check bump steer and correct what it is telling you. norvalwilhelm C3 Tech/Performance 31 12-11-2003 06:55 AM
One final time, Is 11:1 CR OK with 92 octane gas. MotorHead C3 Tech/Performance 45 11-06-2003 08:05 PM
Want to lower one side of car more...but how...? MiamiDave C5 Tech 10 02-26-2003 11:55 PM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
